Home > Maintenance & Mods (L322) > Acoustic Cover removal TD6 - cant get mine off..
rjp996
United Kingdom 2003 Range Rover Vogue Td6 Buckingham Blue
Hi, I’ve been trying to solve an oil leak I look to have from the top of my engine (2003 TD6). Problem I have is that I am having trouble removing the plastic ‘acoustic cover’. What looked like the simplest thing in the world has left me a bit stumped as I am guessing I am missing some screws.
I have managed to remove the ‘silver’ plastic cover down the centre on the engine cover and also the black part on the right hand side and front towards the radiator – all ok by removing the engine cover bolts. However for the final left hand plastic cover I have removed the screw on the front, down the side and one at the back, but for the life of me I can’t find any more screws and the cover still well attached. I took a look in RAVE under the removal of acoustic cover section but can’t see any pictures showing where the screws I guess I am missing are located. Unfortunately the oil leak looks to under the side that I can’t get off (isn’t it always). If anyone could share with me any tips for getting this off, much appreciated.
Post #109157 24th Feb 2012 5:21pm
would the oil filler cap be stopping the removal..
Post #109172 24th Feb 2012 6:07pm
Richcl
United Kingdom 2002 Range Rover HSE Td6 Zermatt Silver
Mine just sits on top of engine, no fixings Embarassed
Post #109200 24th Feb 2012 6:54pm
DaveAngel
2015 Range Rover Vogue SE SDV8 Barolo Black
Front piece first (there is an additional screw hidden down to the left of the front panel). The top left cover has capsulated screws. You will need to remove the filler cap, i would put it straight back on once the cowling is removed to make sure nothing falls into the engine. __________________
2015 FFRR SDV8
2011 FFRR TDV8 4.4 - Gone
2005 FFRR TDV6 - Gone
Post #110414 1st Mar 2012 10:04pm
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
Is the tractor anything like the V8 where you have to remove the air intake box from in front of the windscreen scuttle to get to the two final nuts?
Confused
Post #110448 2nd Mar 2012 8:28am
