![]() | Home > Technical (L322) > Who has 100K+ on original suspension bellows? |
verydisco Member Since: 10 Dec 2009 Location: UK/US Posts: 2952 ![]() ![]() ![]() |
If you plan on keeping it for a while, you'll eventually have to replace them, along with dampers, if you have not change them already.
bergxu Member Since: 18 Jan 2012 Location: Cincinnati Posts: 61 ![]() ![]() ![]() |
Definitely plan on keeping this truck for a good while so yeah, I think you're right.
grzesiul Member Since: 28 Jan 2012 Location: Berkshire Posts: 24 ![]() ![]() |
why change working bags? is there any LR recommendation on doing it every xxxK?? |
No, I am thinking it more as a proactive measure because I travel far and wide for my job and there are vast stretches of nothingness here in the US where I'd really hate to get caught out with a knackered suspension. Of course, a new part can fail too, so maybe I'd better stick with the airplane regimen for longer trips. Then again, most of the US carriers now use piddly little things such as ERJs for most intercontinental flights and, well, the comfort of those isn't quite on par with the Lux interior on the Rangie ![]() Aaron |
I will look through GTR tomorrow wilelt you knwo if found any info on that but would be surprised tofind anything
L322Pilot Member Since: 10 Feb 2011 Location: Solihull Posts: 19 ![]() ![]() ![]() |
bergxu, My FFRR has done 100K miles on the same air bags and I have to agree with you that the seats are more comfortable than a piddly ERJ. However the ERJ does 500 MPH. |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16315 ![]() ![]() ![]() |
Why not inspect them? Check them when in off road setting, look around the bottom of all 4 bags (maybe clean them if not done recently) Your looking for tail tail signs of threads showing and abnormal wear in the rubber... We clean them at every service as grit in the lower bags create wear! That said, i have customers that have done 200k+ without problems and those that have had a punctured bag in under 10k! Craig ![]() |
tsadpt Member Since: 09 Feb 2011 Location: West Sussex Posts: 176 ![]() ![]() ![]() |
I'm at 140k on the original bags... |
DavidP Member Since: 20 Oct 2010 Location: BN Posts: 425 ![]() ![]() ![]() |
just passed 200k [200007kms] on originals. Have a sneaking suspicion that the rear left height sensor is on its way out though |
122k on the original bags and my FFRR was a farmers car before I bought it |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1424 ![]() ![]() |
105k miles on mine. I clean the grit off the front struts pretty regularly, but not really bothered with the rears so far. So far all ok with mine.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35508 ![]() ![]() |
127k on mine and still working ok.......i think |
Thanks for the replies gents. I guess I'll keep the money in the bank and keep my arse in the ERJs |
rmpsmith Member Since: 25 Feb 2012 Location: Surrey, UK Posts: 10 ![]() ![]() |
Hi, I guess it totally depends on where you drive the thing. I've just replaced the fronts on my '03 that's got just 74k on the clock, but then it gets very muddy on a daily basis and was cleaned for the first time in 18mnths in order that they could be replaced. The mechanic wouldn't have been too chuffed with 3 inches of gloopy mud and horse manure! Of course, the rubber will just naturally get brittle and split with age if anything anyway.
