Home > Maintenance & Mods (L322) > Turbo whistle
Andy3681
United Kingdom 2005 Range Rover Vogue Td6 Cairns Blue
Turbo whistle
Sorry as I am sure its been covered before.
The waste gate on the turbo on my TD6 seems to open quite early leading to a whistle ( quiet normally) I dont know if the fault is the wastegate, manifold pressure sensor opening the wastegate or its just on its way out. seems to drive fine with plenty of power, I do run a plug in box but it whistled before it was fitted.
I have read somewhere that the turbo is variable and it sticks leading to the wastegate opening on overboost if the pressure gets to high. or is the wastegate adjustable????
appreciate any comments advice
Thanks Mine was a blue one! Smile
Post #108578 22nd Feb 2012 10:09am
Andy3681
Also vehicle is preloved so I dont know if its been remapped etc
Ta Mine was a blue one! Smile
Post #108580 22nd Feb 2012 10:13am
essexfarmer
United Kingdom 2012 Range Rover Vogue SE TDV8 Santorini Black
If it helps, the turbo on our FF has 'whistled' since the car was new, I have never thought of it as a problem, to be honest I quite like it Smile 12MY Black FF VSE
12MY Orkney Grey HSE Lux RRS
Post #108617 22nd Feb 2012 1:58pm
Andy3681
Thanks
Its done it since I had it thats about 10 months ago and nothing has changed just wondered if it was possible to adjust somthing to stop it? Mine was a blue one! Smile
Post #108632 22nd Feb 2012 3:07pm
Lolo
Ireland 2011 Range Rover HSE TDV8 Santorini Black
Mine whistles or whooshes also when I take foot off accelerator just thought that's how the turbo sounds..quite like it myself..
Post #108677 22nd Feb 2012 9:08pm
You can stop it by decelerating slower, ie letting of the loud pedal slower as the boost then kills itself off and thus there is no excess pressure to bleed off, for the dumpvalve type sound.
For the waste gate one same theory, less go, more slow, less noise Smile I dont often get a woosh unless i have tried to squeeze into fast flowing traffic at low speeds. anything above 40 and the road/tyre noise drowns it out anyway Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #108701 22nd Feb 2012 10:26pm
Flashman
England 2011 Range Rover Autobiography TDV8 Santorini Black
No idea on the wastegate, but my car whistles when you take your foot of the accelerator. It is normal for a turbo on this model. Tom
Current Drive
2011 4.4 TDV8 Autobiography - Santorini Black - Ivory Leather
Previous Drives
2004 Model Vogue Td6 (Touchscreen) - Java Black - Parchment Leather
1994 RR Classic 3.9 V8 Soft dash - Niagara Grey - Grey Leather
1972 Series III SWB Safari - Green (Hand Painted) - Black Plastic
Post #108724 23rd Feb 2012 7:53am
Andy3681
Thanks chaps but whistle is under power it stops on the overrun when easing off at a steady 60 you can just hear it as if the dumpvalve is just passing a bit?? Mine was a blue one! Smile
Post #108739 23rd Feb 2012 8:32am
this 'might' help andy...
http://www.fullfatrr.com/forum/post12326.html#12326 ... - .- -.
Post #108790 23rd Feb 2012 12:31pm
Simes
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
Andy3681 wrote:
Thanks
Yes there is.
The Radio - turn it up louder.
Post #108791 23rd Feb 2012 12:38pm
Andy3681
Thanks Scarey/Stan or is it Scarey stan?
Smile
I replaced the crankcase filter when I bought the car (along with everything else that was funnily not included in the full service the garage was going to do when I bought it like air, pollen, and fuel filters)and it did not affect the whistle. it just always done it, not got worse over 7k miles so might just be somthing it does would not be happy if it did it from new on a £60k vehicle.
I just think if its bleeding air then its bleeding power? but i think there is an optimum manifold pressure? Has anybody else heard about the vanes sticking on the variable turbo or am i making it up?
or can you adjust the dumpvalve?
not sure how its controlled and rave seems a bit vague
Post #108792 23rd Feb 2012 1:05pm
