Home > Maintenance & Mods (L322) > 4 Wheel alignment
4 Wheel alignment
Quick question. How much and how long for a 4 wheel alignment? [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #108192 20th Feb 2012 11:48am
quick reply, depends where you go and who does it...
Mr. Green ... - .- -.
Post #108194 20th Feb 2012 11:49am
wedgel322
United Kingdom 2013 Range Rover Autobiography SDV8 Santorini Black
I had mine done and think it was £65 ish. Had to have it done due to bushes and arms being replaced etc. 2003 Range Rover HSE 3.0 TD6
Java Black, Cream Leather Heated seats all round, Sat Nav, Rear TV's.
2013 Range Rover Autobiography 4.4 SDV8
Black, black and piano black. Rear entertainment system. 22 inch turbines
Post #108213 20th Feb 2012 12:27pm
Stocky
United Kingdom 2019 Range Rover Autobiography 2.0 PHEV Fuji White
Had mine done 6 months ago because of tyre wear on outer edges of front tyres and cost £40. Half hour job.
Was quite a bit out according to the print outs.
Post #108269 20th Feb 2012 4:00pm
NKSC
United Kingdom 2005 Range Rover Vogue SE Supercharged Zambezi Silver
I had mine done last month and it was about £40. It was quite a long way out apparently and it seems to drive a lot better now its sorted.
Post #108275 20th Feb 2012 4:25pm
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
Was this 4 wheel laser alignment?
I need mine doing as my front tyres are scrubbed and pretty uneven.
Post #108277 20th Feb 2012 4:41pm
NKSC
Yes, mine was 4 wheel laser alignment. I had scrubbed inside edges on my front tyres which mde for a skitish drive in the wet.
Post #108280 20th Feb 2012 5:04pm
I've struggled to find somewhere local to do 4 wheel alignment. Loads did front wheel but not all 4. Main dealer wanted £238 but a local 4x4 specialist has quoted £70. Booked in on Thursday. Mine pulls to the left and my right inside edge is knackered. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #108293 20th Feb 2012 5:54pm
Stephen.125
@NKSC exactly the same as mine.
@Rob I'm not that far from you. I used to use a place in Liverpool for my BMWs that used a Hunter machine such always made a great difference.
Post #108302 20th Feb 2012 7:06pm
Knips
United Kingdom 2017 Range Rover Vogue SE SDV8 Santorini Black
@NKSC
Where did you get the tracking done please?...
Post #108343 20th Feb 2012 10:40pm
NKSC
Knips - I had it done at Tanvic Tyres in Melton Mowbray, Leics.
Post #108369 21st Feb 2012 8:46am
