![]() | Home > Technical (L322) > Newbie with a bluetooth problem and a noisy centre console! |
Which model of handset are you pairing... |
James Member Since: 07 Jan 2010 Location: Harrogate Posts: 6 ![]() ![]() |
Trader had some kind of sony ericcson. I have tried Nokia 6230, iPhone, Blackberry Bold, HTC Touch Dual. It's not that they're not pairing properly, they're not even able to see the car as a device to pair to, so I don't think we're talking about handset compatibiilty? |
jayzee Member Since: 14 Oct 2009 Location: UK Posts: 342 ![]() ![]() |
So to recap - you pair the phone and nothing happens, or are you saying you expect to see the phone book?
VMPP Member Since: 12 Jul 2009 Location: Lisboa Posts: 410 ![]() ![]() ![]() |
One time I had a blockage on the whole audio system because of a situation like that. Couldn't adjust volume, disconect radio, etc... Even when leaving the car the screen stayed on.
Hi all
Sounds like a motor moving something to me. Definitely linked to the turning of the ignition key - both on and off. |
Real RR Member Since: 13 Aug 2009 Location: In a Defender Posts: 33 ![]() |
The phone system is supplied by Nokia. Try a different Nokia mobile. I've found that my Nokia will lose pairing and not rediscover the car after synching with my PC via bluetooth. I fix this by temporarily pairing another Nokia to the car first then all is well again with the original. |
Sonds like a full re-set is in order by disconnecting the battery? See how you go from there. |
The doc Member Since: 25 Mar 2007 Location: In car hell :-( Posts: 425 ![]() ![]() |
VMPP I had the ''phone not fitted'' message on my car too but this was resolved with an update at the dealers - used to do it every other day and now it neover does it
I'm thinking the same thing. It's booked into my usual garage for a quick look on Wednesday, will post up the results here. |
Yes, that sounds very likely. Thanks |
