![]() | Home > Technical (L322) > Webasto fuel burning heater remote** |
SAppie Member Since: 08 Feb 2010 Location: Berkshire Posts: 159 ![]() ![]() |
Hi 5imon,
simon1233 Member Since: 13 Jun 2011 Location: Leyland, sometimes Darmstadt Posts: 650 ![]() ![]() |
I was looking at T91 remotes the other day on the bay and was astonished at the difference in prices depending on whose logo is on the remote. Seems that a VW logo'd remote is 1/4 - 1/3 of the price of a Landrover one. If these will work I'm thinking of getting one, but not a Landrover one |
I'm not sure about the other branded remotes, all i know is that the Webasto and obviously LandRover remotes work as I've got them both. MY2007 Vogue SE TDV8 - Tonga Green / Sand
Just bought a genuine landrover one for £25 on eBay |
5IMON Member Since: 27 Nov 2011 Location: London Posts: 165 ![]() |
It's a yer 2007 vogue not an se , does that matter? |
The other thing is, there is no aerial stuk to the window in the boot , does this mean I dont have the receiver? Tdv8 |
no, that makes no difference, however you need to check that it has the receiver fitted in the first place.
tomthevet Member Since: 14 Jan 2012 Location: Scotland Posts: 283 ![]() ![]() ![]() |
Whereabouts is the receiver situated??
HI, It's located in the boot, on the right hand side, open up flap, and then its located behind the fuse box, you will have to undo the fuse box and flip it over to see it. I'm sure I posted a pic somewhere in the forums... here is a link to one of many bits and pieces I put up regarding all the issues I had in getting the remote to function: http://www.fullfatrr.com/forum/post71843.html#71843 use the search function, it works well.... ![]() MY2005 Discovery 3 - Silver / Biege |
I never found the aerial stuck to the window that others have mentioned. Maybe its a different system in the MY2007 onwards?? I had to actually remove the fuse box to actually see it . Has a big webasto sticker on it. MY2007 Vogue SE TDV8 - Tonga Green / Sand MY2005 Discovery 3 - Silver / Biege |
FBH uses the tv ariels in the rear side windows. There isn't a specific ariel |
Where is the in number located ? How many characters is it? |
The VIN is located in the front windscreen, at the bottom of the passenger side when looked at the car from outside.
The receiver is located on the back of the rear fusebox at the end closest to the boot. you can see that there is a cable coming down from the TV ariel (yellow connector) and also a power connector.
