Home > General > Help please
igore
England 2002 Range Rover Vogue Td6 Adriatic Blue
Help please
Hi chaps, I wonder if you could help me I tried to jump start the range today (flat battery) and the first time I tried before adding the jump leads I still had dash lights and all but since adding the jump leads I can't even turn the key????? And I have no power at all Big Cry Big Cry . Has anyone got any ideas where I've gone wrong I used the two terminals that's not the battery itself. ONE LIFE LIVE IT
Post #106897 12th Feb 2012 10:46am
did you use proper cables and was donor car running.....
probably needs a new battery ... ... - .- -.
Post #106899 12th Feb 2012 10:56am
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
Ouch!
The key turning could be due to the security lock on the ignition barrel which reads the chip in the key. This required power. I wonder if attaching the jump leads could have blown the fuse?
It could also be that the battery is utterly dead, could be worth removing it and charging off the car?
I know some on here say it's not wise to jump the range but I did it a handful of times with no issues at all.
Another thing could be that once the battery is completely flat it may be hosed- i.e. it may not ever hold a viable charge when left unattended.
Post #106904 12th Feb 2012 11:00am
If you have a battery charger undo the battery -ve lead and charge the battery.
Post #106907 12th Feb 2012 11:06am
