Home > Technical (L322) > Gearbox advice
Page 1 of 3 123>
Mikeyjd
Wales 2003 Range Rover SE Td6 Zambezi Silver
Gearbox advice
OK my TD6 is approaching that time when the gearbox seems Likely to go kaput. Nearly 100,000 miles on the clock. Recent symptoms being, lazy take up in the mornings, occasional cattle grid type sound for short occasions etc.
It always changes gears smoothly though and never bangs into gear or sticks in any gear, but I am preparing myself for the inevitable. I suspect that either the torque converter or gearbox is on its way out.
I would appreciate some advice or recommendations on where to go for honest And accurate diagnosis and possible repair. I live on the Welsh borders close to Chester, but would happily travel a reasonable distance (50+ miles - maybe more) No longer FF owner but still interested. Present car Jaguar XE
Previous car Td6 SE
Previous LR- Disco 300TDi Auto
Post #106741 11th Feb 2012 12:37am
Richcl
United Kingdom 2002 Range Rover HSE Td6 Zermatt Silver
Go into a specialist now, explain your symptoms (I wish I did)
At least get them to check fluid level etc
Post #106743 11th Feb 2012 12:47am
Mikeyjd
That's my plan, I was hoping for some recommendations or suggestions rather than just randomly picking someone from yellow pages.
I assume you had a similar problem that got worse. No longer FF owner but still interested. Present car Jaguar XE
Previous car Td6 SE
Post #106744 11th Feb 2012 1:00am
Richcl
Yes, my gearbox was reparied in Gloucestershire.
Mine suffered the same symptoms as yours, probably went on for thousands of miles before it expired, then it went on the drive to my house (luckily), a specialist well may save you £££'s if caught early..
Post #106745 11th Feb 2012 1:06am
mrblonde
United Kingdom 2003 Range Rover Vogue Td6 Adriatic Blue
Had my TD6 box rebuit in July (95,000 miles), cost £2k. Had same symptoms as you, as well as holding onto gears longer especially when cold.
finally went and ran in 'safe mode' til Mr AA condemed it. I wish I'd had mine serviced, oil and filter change and flushed through, think Indy's were quoting about £180 ish to do it
Post #106784 11th Feb 2012 12:39pm
Mikeyjd
I had my fluid and filter changed a few thousand miles ago after reading all the woes on here. Don't know if it delayed or exacerbated the problem though.
Anyway, still waiting for any recommendations for places to go if anyone can suggest. There is an auto box specialist about 10 miles from me but don't know how good they are. No longer FF owner but still interested. Present car Jaguar XE
Previous car Td6 SE
Post #106788 11th Feb 2012 12:59pm
mrblonde
Sorry cant help there mate, i'm on Hertfordshire, went a the local auto box specialist, got about 20+ years behind him, family run business with a good reputation locally.
You could google the companies name see what comes up? might have feedback or recommendations on other RR boards, or even other manufacturers forums
Post #106801 11th Feb 2012 2:56pm
ZF Powertrain about 70 miles from you
Post #106803 11th Feb 2012 3:12pm
Mikeyjd
I have the GM box not the ZF. Thanks anyway. No longer FF owner but still interested. Present car Jaguar XE
Previous car Td6 SE
Post #106814 11th Feb 2012 6:06pm
Sorry about that, been looking at ZF boxes the last two days and my head's spinning Shocked
Post #106816 11th Feb 2012 6:16pm
Mikeyjd
No probs mate, thanks for replying anyway. No longer FF owner but still interested. Present car Jaguar XE
Previous car Td6 SE
Post #106820 11th Feb 2012 6:29pm
Mikeyjd
This place is only 10 miles away. The website isn't very inspiring but they seem to be very experienced. Anyone used them?
http://www.transcentre.co.uk/trans.html No longer FF owner but still interested. Present car Jaguar XE
Previous car Td6 SE
Post #106822 11th Feb 2012 6:32pm
Check eBay as there is a place in Rotherham doing same day exchange for already recon'd box's and torque converters but not sure how good they are and a bit far from you Sad FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #106838 11th Feb 2012 7:44pm
Mikeyjd
Thanks for that, the distance isn't a huge problem, I am more concerned right now about finding what the problem is. Torque converter, box, or even both.
Once I have the problem diagnosed I can price up repairs etc. that's why I want to go somewhere who will give me an honest diagnosis. Hopefully a good place will also be entrusted with the repair. No longer FF owner but still interested. Present car Jaguar XE
Previous car Td6 SE
Post #106842 11th Feb 2012 7:55pm
SteveMFr
Site Sponsor
In Germany, ZF will do an overhaul of the GM gearbox. Not cheap- but you know it's done well.
That said - they don't do the Sonnax valve body modification. I would def have this done.
I think the only way to saye a GM5L40E gearbox that is on its way out with noticeable symptoms is to replace the valve body and torque converter and even then you are taking a risk on debris in the box - at nearly half the cost of a full rebuild. Just drive it till it goes and then have it repaired.
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #106863 11th Feb 2012 9:40pm
Page 1 of 3 123>
