![]() | Home > Technical (L322) > Gearbox advice |
@Mikeyjd - tough call. 100k miles... As I said, I've heard of people doing a fluid change - and that only seemed to accelerate the demise of the gearbox. You do have a pressure related problem, but as it is a leak down issue I don't know if a fluid change will do much for you. And the new detergents etc in new fluid may actually cause the quick demise I mentioned above.
and @ Simes To you both: YES! This is exactly what happened here. The softer alloy was most likely used to save time and money on machining the valve body casting. And BMW canceled the follow-up contract with GM Powertrain for a 6 speed gearbox (there are articles if you ggogle). And GM Powertrain sold the Strasbourg plant where the 5L40/5L50 were built. This was in liquidation for a while but I think they are operational in some form again. One of the problems we are faced with today: short term (shareholder value) thinking. ![]() RRC 2Dr, RRC 4Dr, P38, and 2 L322s (wife thinks I'm nuts - prob right, too) |
salb Member Since: 25 Feb 2012 Location: blackburn Posts: 332 ![]() ![]() ![]() |
Hi Steve,
bozmandb9 Member Since: 06 Dec 2010 Location: Wallingford, Oxfordshire Posts: 1037 ![]() ![]() |
There you go then, apart from the manufacturers troubleshooting guide recommending a fluid change (found it somewhere on the D3 site, but now for the life of me I can't relocate it |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 992 ![]() ![]() |
In the particular case of the ZF (6-speed) 6HP26 transmission the 2-1 rollout shift ‘thump’ is extremely well known and widely documented on forums as it been a feature on Jaguar (where it’s generally known as ‘the lurch’) and BMW (where it’s generally know as ‘the tranny slam’) vehicles which were fitted with this transmission 3 years before it appeared in the L322.
VMPP Member Since: 12 Jul 2009 Location: Lisboa Posts: 410 ![]() ![]() ![]() |
Problem is not Salb, it's me.
47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048 ![]() ![]() |
I did a triple flush on my box and everything is fine.
