Home > Technical (L322) > Front cigarette lighter / power plug not working
2003 Vague
JJust went to charge up my phone and discovered theres no juice coming through the front lighter socket.
Is there an easy way to access the rear to check that it's not a dodgy wire? Any other ideas on what it could be?
Thanks
Post #106328 9th Feb 2012 1:22pm
Errr, fuse? Smile
Post #106331 9th Feb 2012 1:36pm
2003 Vague
That just seemed a bit too obvious. You're right I should check it.
Can anyone confirm what fuse number it is?
Incase it's not the fuse, how do I go about accessing the back of the socket to check it's not just a case of the spade connector coming off?
Post #106332 9th Feb 2012 1:40pm
ebajema
Check the other cabin lighter/power points as well (not the trunk one, that is separate). That way you can check if it is fuse (none will work) or the front one. Not sure if your car has one in the back (console between the front seats) and/or in the cubby hole under the armrest like mine. MY 2010 5.0 SC Galway green and sand interior!!
Post #106333 9th Feb 2012 1:46pm
Rear fuse box, Fuse 1 20A upto 2005, after that no idea. Smile
Post #106334 9th Feb 2012 1:50pm
Tesh
United Kingdom 2004 Range Rover Vogue Td6 Java Black
I have the same problem with the one in the boot
Is it on a separate fuse, if so where is the fuse?
Post #106348 9th Feb 2012 2:56pm
Fuse 7 20A on the fuse board in the boot compartment , drivers side.
Post #106349 9th Feb 2012 3:03pm
Simes
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
I feel your pain brother - mine has stopped working too!
All the others work OK - just the front one is dead. Probably a wire dropped off - but haven't sussed how to get to the back of it yet!
Post #106367 9th Feb 2012 4:01pm
Only the one in the rear boot space is live with ignition off - but of course, you knew that already.
Look in your manual P257 onwards for fuse information. Discovery 4 HSE
Post #106371 9th Feb 2012 4:04pm
Simes
Not sure how old the OP's car is - but mine are all live all the time (or at least they were!)... One of them is never live at the moment...
Post #106378 9th Feb 2012 4:11pm
I think you just lever it out with a small screwdriver, don't think its anything fancy, its sort of srpung loaded and clips in. Discovery 4 HSE
Post #106392 9th Feb 2012 4:28pm
Simes
You don't sound very sure - can you nip out and break yours before I break mine - just to check?
Post #106397 9th Feb 2012 4:32pm
I believe you have to remove the centre console finisher (the black bit down both sides of the gear stick, to get at it. There are three connectors on the underside of the accessory socket and it appears to be secured with torx bolts from underneath. .
Post #106453 9th Feb 2012 10:12pm
mzplcg
Post 2005 models are also fused in the boot, right hand side cubby. If you've got the posh version (VSE) then they use an extra fuse for the 2nd set of sockets.
Post #106469 10th Feb 2012 8:06am
Marksman
Many pre 2008 vehicles had the front power socket disconnected by dealers as a precaution as some fires had been attributed to the positive shorting out, you will need to dismantle the centre console to find it ( the centre connector removed and taped up) I believe there is a technical bulletin around somewhere that alludes to it
Post #106825 11th Feb 2012 6:46pm
