![]() | Home > Technical (L322) > Front cigarette lighter / power plug not working |
Errr, fuse? |
2003 Vague Member Since: 30 Jan 2012 Location: South Northants Posts: 20 ![]() |
That just seemed a bit too obvious. You're right I should check it.
Check the other cabin lighter/power points as well (not the trunk one, that is separate). That way you can check if it is fuse (none will work) or the front one. Not sure if your car has one in the back (console between the front seats) and/or in the cubby hole under the armrest like mine. MY 2010 5.0 SC Galway green and sand interior!!
Rear fuse box, Fuse 1 20A upto 2005, after that no idea. |
Tesh Member Since: 27 Feb 2010 Location: Co Durham Posts: 138 ![]() ![]() ![]() |
I have the same problem with the one in the boot
Fuse 7 20A on the fuse board in the boot compartment , drivers side. |
Simes Member Since: 30 Aug 2011 Location: Hinckley Posts: 964 ![]() ![]() ![]() |
I feel your pain brother - mine has stopped working too!
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6373 ![]() ![]() ![]() |
Only the one in the rear boot space is live with ignition off - but of course, you knew that already.
Not sure how old the OP's car is - but mine are all live all the time (or at least they were!)... One of them is never live at the moment... |
I think you just lever it out with a small screwdriver, don't think its anything fancy, its sort of srpung loaded and clips in. Discovery 4 HSE 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 Hard Top *Gone:L462 D5 HSE LUX, L663 Defender 110 HSE, Discovery 3 HSE, 2014MY Range Rover Sport 5.0 Supercharged AB Dynamic; L405 Exec Vogue SE 4.4, 5.0 Supercharged Autobiography, Defender TDCi XS CSW, Defender TD5 HT, Vogue SE TDV8, Vogue TD6, RRSport SC 4.2V8, Classic 3.9 Vogue Auto, Land Rover Series 3 SWB |
You don't sound very sure - can you nip out and break yours before I break mine - just to check?
I believe you have to remove the centre console finisher (the black bit down both sides of the gear stick, to get at it. There are three connectors on the underside of the accessory socket and it appears to be secured with torx bolts from underneath. .
Post 2005 models are also fused in the boot, right hand side cubby. If you've got the posh version (VSE) then they use an extra fuse for the 2nd set of sockets. |
Marksman Member Since: 24 Dec 2010 Location: Durham Posts: 73 ![]() ![]() ![]() |
Many pre 2008 vehicles had the front power socket disconnected by dealers as a precaution as some fires had been attributed to the positive shorting out, you will need to dismantle the centre console to find it ( the centre connector removed and taped up) I believe there is a technical bulletin around somewhere that alludes to it |
