Home > General > brake pad warning light on - instant MOT failure?
Dolphinboy
Just about to take the old girl in for another faultless (hopefully) MOT. and the brake pad sensor warning light (red circle) has just come on the dashboard. Is this an automatic fail as in the brake pads need replacing or can they still be allowed a pass?
Post #106290 9th Feb 2012 11:54am
I think with the new system it is a fail im afraid.
If you want to take the risk they won't take the wheels off to check pad thicknes you could always disconnect the offending sensor if awaiting pads. I wouldn't reccomend this unless the light has JUST come on and there is still decent life left in them for the trip to the station, test and trip home whilst waiting for them to be replaced mind. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #106292 9th Feb 2012 12:05pm
supershuttle
I wouldnt have thought that the light being on causes a fail, i would expect they will look to see how much is left on the pads. It's a bit like the spare wheel, no spare that's fine (many new cars don't have one), bald spare - fail. Geoff
Post #106293 9th Feb 2012 12:05pm
Even if you do disconnect the sensor the tester will look at the pads and fail it because there is not enough material on them
Post #106295 9th Feb 2012 12:07pm
Simes
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
supershuttle wrote:
bald spare - fail.
Is that true?
I've never had a tester look at the spare - ever - surely, as it's not being used - it's effectively just luggage. How can they fail you for that? Would they fail me for lack of tread on the wheels on my Tuba case just because it's in the boot?
Post #106302 9th Feb 2012 12:15pm
The Mot Inspection Manual makes no reference to the brake wear warning indicator lamp.
The pads are just required to have 1.5mm thickness left to pass.
The chances are yours are thicker than that.
Personally I wouldn't leave them to 1.5mm or anywhere near.
Post #106303 9th Feb 2012 12:15pm
supershuttle
I'm thinking the light came on for a reason, the car is saying " new pads please" might be best to get them done before booking in - if you have a couple of days it's a pretty strait forward job providing you can get the wheel nuts undone Shocked Geoff
Post #106304 9th Feb 2012 12:16pm
The Mot test applies to tyres fitted to road wheels only, you don't even need a spare as many cars don't these days.
Post #106305 9th Feb 2012 12:18pm
supershuttle
With regard to the spare that may or may not be correct but is based on my actual experience. It is reasonable to assume you would use it in the event of an emergency. Geoff
Post #106308 9th Feb 2012 12:19pm
I thought part of the new test was regarding warning lights on the dash coming on and going off and that if it stayed on that the affected system caused a fail?? Surely the pad light is the same as the low fluid light on an RR??
Gotta admit i aint ever seen it as i haven't RTFM Very Happy FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #106310 9th Feb 2012 12:20pm
If it's not in the manual it's not a testable item so it can't be failed.
Whatever MOT Testers say.
Post #106311 9th Feb 2012 12:21pm
supershuttle
I think I'll rephrase - bald spare they don't like - although this is pretty irrelevant in this topic: In fact I'm sorry I mentioned it, I really must have something better to do than lurk on here all morning, oops I mean all day, the morning has flown by Very Happy Geoff
Post #106313 9th Feb 2012 12:27pm
Andy3681
United Kingdom 2005 Range Rover Vogue Td6 Cairns Blue
Well I keep an eye on my pads and thought they were about two thirds worn when light came on so plenty of life left.
you need to get the warning light to reset after which can be a mare of pushing the trip meter and info button on the dash info on here somewhere and defo on google.
Probably worth replacing the sensor to as they are only about £8 front is on the nearside and easy rear is on the offside and a bit fiddly
ta Mine was a blue one! Smile
Post #106314 9th Feb 2012 12:32pm
