![]() | Home > General > brake pad warning light on - instant MOT failure? |
I think with the new system it is a fail im afraid.
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3872 ![]() ![]() ![]() |
I wouldnt have thought that the light being on causes a fail, i would expect they will look to see how much is left on the pads. It's a bit like the spare wheel, no spare that's fine (many new cars don't have one), bald spare - fail. Geoff |
Even if you do disconnect the sensor the tester will look at the pads and fail it because there is not enough material on them |
Simes Member Since: 30 Aug 2011 Location: Hinckley Posts: 964 ![]() ![]() ![]() |
Is that true? I've never had a tester look at the spare - ever - surely, as it's not being used - it's effectively just luggage. How can they fail you for that? Would they fail me for lack of tread on the wheels on my Tuba case just because it's in the boot? |
The Mot Inspection Manual makes no reference to the brake wear warning indicator lamp.
I'm thinking the light came on for a reason, the car is saying " new pads please" might be best to get them done before booking in - if you have a couple of days it's a pretty strait forward job providing you can get the wheel nuts undone |
The Mot test applies to tyres fitted to road wheels only, you don't even need a spare as many cars don't these days. |
With regard to the spare that may or may not be correct but is based on my actual experience. It is reasonable to assume you would use it in the event of an emergency. Geoff |
I thought part of the new test was regarding warning lights on the dash coming on and going off and that if it stayed on that the affected system caused a fail?? Surely the pad light is the same as the low fluid light on an RR??
If it's not in the manual it's not a testable item so it can't be failed.
I think I'll rephrase - bald spare they don't like - although this is pretty irrelevant in this topic: In fact I'm sorry I mentioned it, I really must have something better to do than lurk on here all morning, oops I mean all day, the morning has flown by |
Andy3681 Member Since: 13 Jan 2012 Location: Newcastle under lyme/ Le Dorat Haute Vienne Posts: 912 ![]() ![]() ![]() |
Well I keep an eye on my pads and thought they were about two thirds worn when light came on so plenty of life left.
