Home > General > best straight swap headlight bulbs?
Page 1 of 3 123>
mrblonde
United Kingdom 2003 Range Rover Vogue Td6 Adriatic Blue
Am after upgrading the headlights in my FFRR, lad at work was going on about ballasts and resistors etc and totally lost me Sad
Are there any standard fit, straight swap headlight bulbs that are a lot better than the standard one? If so, what are best to get? mines a 2003 Vogue, so the earliest of the FFRR headlight shape
Cheers guys
Post #104023 27th Jan 2012 11:27pm
fisha
The bulbs are d2s bulbs. You can get cheap ones on Ebay, or genuine ones from the likes if hid4u. The genuine ones are a good bit more expensive, but you take your chances depending on budget.
Don't be fooled thinking that the higher the colour temp number, the brighter it'll be, its the opposite. 4300k is the original spec, 6000k appears whiter to look at, but is slightly dimmer.
The bulbs just pop in and out, no harder than normal bulbs and if your existing ones work, you won't have to touch the ballasts. I suggest you read up some quick guides on the differences between hid bulbs.
I recently bought 6k Phillips ultinon bibs off Ebay recently and really like them V8 or else ...
Post #104045 28th Jan 2012 4:43am
i've got 6000k bulbs which i brought of ebay for £17 and they do make a great difference in respect of the light being whiter ..
btw, its best to get 2 sets as if one goes you have a replacement ready to fit.. ... - .- -.
Post #104156 28th Jan 2012 6:28pm
Simes
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
Just bought a set for the same price to replace mine as one hass gone a bit flickery over bumps etc when they are cold - apparently a sign of them starting to fail.
Tricky to change or a piece of cake?
Post #106253 9th Feb 2012 10:07am
easy, just dont touch the filament bit... ... - .- -.
Post #106254 9th Feb 2012 10:10am
Simes
Cheers Stan - not had a chance to look under the bonnet in daylight yet to see if you can get to them - I assume they come in and out through the back like halogens?
Post #106256 9th Feb 2012 10:23am
yep.. Thumbs Up ... - .- -.
Post #106257 9th Feb 2012 10:31am
Simes
Cheers...
If it takes me days I'll come and shine them in your eyes you know Laughing
Post #106258 9th Feb 2012 10:32am
Laughing
do the near side first , there's more room to 'look' at the way its setup.. ... - .- -.
Post #106259 9th Feb 2012 10:36am
Simes
Cheers.
Still waiting for the new bulbs - should be able to do it over the weekend though.
Don't want to fiddle about until I've got the bits in case I make it worse!
Post #106262 9th Feb 2012 10:40am
daveo
i think a 2003 would be D1S bulbs...but they could be halogens so check first.. V8 facelift Range Rover Autobiography 22" wheels.
Post #106440 9th Feb 2012 8:51pm
pretty sure the vogues all come with bi-xenons which are d2s bulbs dave... ... - .- -.
Post #106483 10th Feb 2012 8:43am
Simes
No - these are definitely bi-Xenons.
Post #106504 10th Feb 2012 9:33am
The bi-xenon part is a powered flap in the headlight that changes the beam pattern on full beam... Nothing to do with the bulbs...
Craig Thumbs Up
Post #106507 10th Feb 2012 9:43am
thanks for the clarification craig.. Thumbs Up ... - .- -.
Post #106508 10th Feb 2012 9:44am
Page 1 of 3 123>
