Home > Technical (L322) > FSR?
bozmandb9
2013 Range Rover Vogue SE TDV8 Causeway Grey
FSR?
Guys,
I've done the searches, and not found the answer. I have an issue with my heating and I suspect FSR, but am not sure.
When on auto, very little air seems to come out of anywhere. If I use the manual controls, I get air out of the relevant vents.
Occasionally the heating will just switch off completely.
So does this sound like FSR?
Cheers,
David 2012 SDV8 Vogue SE
Post #105676 6th Feb 2012 12:59pm
Sounds like it to me.
Check the connections first, and that the FSR is properly seated in its slot.
I've written to LR to ask them to locate the FSR on their new model in a more inaccessible place Mr. Green .
Post #105678 6th Feb 2012 1:13pm
piersie
England 2003 Range Rover Vogue Td6 Epsom Green
I have a brand new one still in its box,bought from Dan last sept. and im not far away from Henley.
Am open to a decent offer. Thumbs Up
Post #105929 7th Feb 2012 4:25pm
T24RES
What sort of age do these things pack up?
On auto my fan speed has a dicky moment every two or three minutes then resumes normal service. A little like if you flipped the fan speed up to maxfor a second then returned to auto.
Thoughts...............?
Post #106045 7th Feb 2012 11:29pm
bozmandb9
Piersie, you have PM! Thumbs Up 2012 SDV8 Vogue SE
Post #106169 8th Feb 2012 9:47pm
could be the start of a fsr failure ian.. ... - .- -.
Post #106229 9th Feb 2012 8:47am
T24RES
Big Cry
Post #106459 10th Feb 2012 5:52am
Cappo
2006 Range Rover Vogue 4.4 V8 Java Black
I have a brand new one still in its box, bought from Guy Salmon's last Sept but I'm a bit further away from Henley!
Post #106472 10th Feb 2012 9:12am
any 'royal' duties in kent ian... Mr. Green ... - .- -.
Post #106477 10th Feb 2012 9:31am
T24RES
Whistle
Post #106580 10th Feb 2012 2:19pm
luckyrobp
United Kingdom 2002 Range Rover Vogue Td6 Adriatic Blue
I have got an 02 td6 with 154,000 miles on the clock.
When I bought it (148k) the fan wouldn't work.
the guy at the dealers played with the plug and it came on. Luckily I watched what he did as it kept going off.
I eventually bought a chunk of harnness and had it spliced in to the original as you can't get a new plug.
It appears that the pins are too small for the power going through them and it melts the plug.
Gave up on the dealer (thornham car sales near Rochdale, and wouldn't touch them with a barge pole again)
Post #122752 20th May 2012 12:10pm
