![]() | Home > Technical (L322) > Possible Alternator Problem, Advice and Help Please? |
SAppie Member Since: 08 Feb 2010 Location: Berkshire Posts: 159 ![]() ![]() |
Hi Carlos,
carlos50 Member Since: 03 Feb 2011 Location: North England Posts: 717 ![]() ![]() ![]() |
SAppie
Hi,
Thanks, i will take a look tomorrow, may charge it first then check in in the pm, or will that provide a false perception of the battery condition?.
It wouldn't surprise me if the garage wrecked the battery . batteries when old get a sort of memory and if taken below this threshold they never recover....... It is important to keep it charged properly.
I'm just concerned that i buy the battery and the alternator kills it. I will boost it tomorrow and check the voltage. |
Yes for sure, you obviously should make sure the alternator is doing its job. My guess is that it's perfectly fine.
Cheers SAppie
I think they take the same battery. I actually bought an original battery from Landrover. I seem to recall that it was only about £115 a year ago. I think that it is only 95Ah which is the correct one for the car, but from reading another thread on the forum, it may be better to get the larger capacity 110Ah battery, although I'm not convinced that the fitting is a straight swap as I think the terminals are on the opposite end....?? I think too that the AGM technology is better. MY2007 Vogue SE TDV8 - Tonga Green / Sand
I will ensure its a min 95Ah (with 800CCA) with the correct fitment. It seems lots of them online are the same battery even though advertised for petrol or diesel models. |
Good luck, let us know how you get on! |
Carlos you need one of these puppies http://www.eurocarparts.com/ecp/c/Land+Rov...amp;000020
jim2RRs Member Since: 07 Feb 2012 Location: Genesee, Colorado Posts: 147 ![]() ![]() ![]() |
Quick alternator check:
Went out this morning and she was dead, enough to open the doors but not to start. Its on charge now so will leave it this morning and check again later |
