Home > Technical (L322) > crankcase problems??? |
simonmanx Member Since: 17 Feb 2010 Location: Isle of Man Ballasalla Posts: 157 |
i have just had a new turbo but im still getting lots of white and blue smoke I have fitted the new vortex breather and housing but still the same so restripped and the turbo is fine but i seem to have a lot of oil in the induction and the compressor side of the turbo but seals look fine !!! has anyone had problems with crankcase pressure ? to add my dipstick is not blowing out and i dont have too much oil in I inspected the vortex to see if i had filled up but only condensation !!! turbo technics are saying it sounds like crankcase blockage ??????????? |
7th Feb 2012 6:53pm |
Your inter cooler would be my first stop.
7th Feb 2012 7:14pm |
forgot to add when i restarted i got engine run over when i tapped the throttle and lots of smoke . my turbo ahd failed badly so do you think my intercooler coud have partially filled ? |
7th Feb 2012 7:46pm |
Certainly!! On a diesel if a turbo fails its always worth checking the inter cooler as they can suck it up and then over run on the oil alone, go past their maximum design rpm and then self implode. Search for Renault 2.2dci in YouTube and you'll see it in action. It's a good way to junk your car that's for sure FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
7th Feb 2012 8:06pm |
Even found one from Solihull for you to view...
7th Feb 2012 8:18pm |
wow mine was only for a second maybe 2 but nothing like that |
7th Feb 2012 8:27pm |
all running well but still need to check my plumbing as per my other post !!
8th Feb 2012 7:51pm |
