Home > Technical (L322) > diagram / schematic
simonmanx
Isle Of Man 2005 Range Rover Vogue SE Td6 Java Black
diagram / schematic
hi does anyone have a schematic showing the vacum pipework route / connections from the turbo charger to other local components on the TD6 ? Wink
Post #105999 7th Feb 2012 9:15pm
just looked on rave and there's a bit of stuff on there..... ... - .- -.
Post #106000 7th Feb 2012 9:19pm
simonmanx
where do i get rave from ??
Post #106007 7th Feb 2012 9:29pm
links are on the wiki.. ... - .- -.
Post #106008 7th Feb 2012 9:31pm
simonmanx
cant find anything on rave
Big Cry Big Cry
Guys i need to check :
1 does the small vacumm pipe from the turbo go straight upto the plug in turbo boost unit on the left hand side inner wing besides airbox
2 does the small black hose from the rear of the cylinder that is just above above the plug in boost unit also plug in besides the turbo vacumm pipe and if so is the turbo the one to the left
3 does the vacuum pipe that comes across the front of the engine (right to left then plug into the front of the cylinder above the plug in unit
please help hope that makes sense Rolling Eyes
Post #106017 7th Feb 2012 10:05pm
Blimey that was a quick download:700mb in the 2 minutes between posts Wink .
Post #106032 7th Feb 2012 10:39pm
simonmanx
2 min you say Question Question Question 8.31 to Arrow 9.05 last time i looked was 34 mins Exclamation plus i never downloaded it i read online ! Thud
Post #106039 7th Feb 2012 10:56pm
simonmanx
Guys can anyone help ?? i need to check to ease my mind :
Post #106140 8th Feb 2012 7:46pm
