Home > Maintenance & Mods (L322) > TD6 Changing alternator belt, anything else?
mrblonde
United Kingdom 2003 Range Rover Vogue Td6 Adriatic Blue
As some of you will know, been having trouble with battery drain/non charging issues so going ot change the alternator belt for peace of mind (along with the FSR, even tho I had the upgrade done). Shall I do the air con drive belt while Im at it? And is it worth changing anything else while I'm laying under her?
Cheers guys
Post #105954 7th Feb 2012 5:46pm
The air-con belt has to be removed to allow access to the poly-v-belt so you are as well changing at the same time. Might be worth checking the tensioner pulley and idler pulleys while you are in there
Post #105990 7th Feb 2012 7:24pm
mrblonde
Cheers 47p
Is it self explainatory how to get at it and do? Bit of a newbie with working on RR's. Better to get to them under the car, or from up top?
Post #106131 8th Feb 2012 5:01pm
You are best with access from top and bottom.
Seems you don't need to remove the A/C belt to change the poly-v-belt according to this image Thumbs Up Still worth changing at the same time though
Post #106137 8th Feb 2012 6:02pm
