Home > Maintenance & Mods (L322) > TD6 Changing alternator belt, anything else? |
The air-con belt has to be removed to allow access to the poly-v-belt so you are as well changing at the same time. Might be worth checking the tensioner pulley and idler pulleys while you are in there |
7th Feb 2012 7:24pm |
mrblonde Member Since: 24 Jan 2012 Location: Cambs Posts: 728 |
Cheers 47p
8th Feb 2012 5:01pm |
You are best with access from top and bottom.
8th Feb 2012 6:02pm |
