Home > In Car Electronics (L322) > reversing camera......works sometimes |
spidermanUK Member Since: 25 Nov 2011 Location: North Herts Posts: 3 |
Similar problem here!
7th Feb 2012 2:11pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35445 |
might be worth doing a search on the forum.. ... - .- -.
7th Feb 2012 2:12pm |
You'll need a new camera £500 |
7th Feb 2012 2:13pm |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3754 |
+ fitting |
7th Feb 2012 2:21pm |
DavidP Member Since: 20 Oct 2010 Location: BN Posts: 425 |
My camera stared playing up like this. Replacement camera was £140ish + fitting took less than an hour. Worked perfectly since. |
7th Feb 2012 3:56pm |
David, where did you get your camera and what make / spec is it. LR have quoted me £600 ish plus VAT! |
7th Feb 2012 8:23pm |
For £140ish probably this ……
7th Feb 2012 9:06pm |
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 |
hi, not that bad..it will be the camera. the seal goes on them and the moisture gets in...but at the camera end you will have 12v and a signal so there are quite a few after market ones that can be fitted there if you dont want to pay landrover prices saying that i pick up a factory camera for 40 quid
7th Feb 2012 10:32pm |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 |
Daveo... That link you posted, that camera will have similar wiring to the FFRR camera I take it? Previously..
7th Feb 2012 11:32pm |
yes its 12v and you will need to convert the rca to smc connector, you can pay more for better quality cameras but that or something along them lines, you will have to fix it under the spoiler V8 facelift Range Rover Autobiography 22" wheels.
8th Feb 2012 12:03am |
Camera came from Caffyns at Lewes.
8th Feb 2012 7:23am |
Lolo Member Since: 16 Feb 2012 Location: Leinster Posts: 608 |
My camera on 06 vogue is banjaxed, took off spoiler messed with the cables and nothing only flickers if I'm lucky. It is wrecking my head Any suggestions for a straight swap aftermarket camera that fits into the space for the old cam? |
16th Feb 2012 11:04pm |
Woohoo finally tracked down a genuine second hand one from cws4x4. 50 quid. Delighted. |
17th Feb 2012 11:04pm |
my camera arrived today, so i have just one question now, how do i connect to my car because the wires from my existing camera connection were cut and taped together(previous owner i assume).. The red and black wires will be easy to just tape together, but the gold connection, what do i do with that, should i cut it off the new camera or..? |
24th Feb 2012 3:06pm |
