Home > In Car Electronics (L322) > reversing camera......works sometimes
Page 2 of 3 <123>
video cable normally has a centre and outer cables...connect centre to centre etc..
Post #109102 24th Feb 2012 3:12pm
Lolo
Ireland 2011 Range Rover HSE TDV8 Santorini Black
thanks, ok cause the centre of thye video cable is tiny like only one or two strands of wire, v easy to break..will give it a go, hope i dont regret cutting it off Shocked
Post #109103 24th Feb 2012 3:18pm
i mess around with cctv cameras around the house and i agree the inner cable sometimes is very thin..
Post #109104 24th Feb 2012 3:21pm
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
Also with the fine Coax it's very easy to get ground loops. We use RA8000 in work sometimes with 1.0/2.3 connectors which are similar to the connector on the camera but with additional locking mechanisms and we sometimes with digital communications have a real nightmare and end up re-terminating them.
A mile away from RG58/59
It may be wise to ask Mr. Dan the Duckworth's man about a new loom.
I've ordered one for a new camera and it wasn't expensive. Was planning when it arrives to swap out the camera and take some pics for a write up.
Also a possibility it's knacked is if the cable got water in and caused a high VSWR.
Good luck! Thumbs Up
Post #109105 24th Feb 2012 3:26pm
Lolo
ok i was thinking bout a new loom to be on the safe side, but i havent been able to get a wiring diagram..with the spoiler off where do the wires go..?
Post #109122 24th Feb 2012 3:52pm
Lolo
Yippee
Installed the camera, should have been straight forward but as usual with these cars it wasn't..! The screwhead that keeps the casing on the camera was worn so that took a lot of effort to get off. Once I got angry with it it came off in one piece..! Then the wiring should have been straight forward but as stated before my connections were cut. Happy days, working camera.. Very Happy had a look at the old one and I could see moisture inside the glass so that was clearly the culprit to the problem
Post #109355 25th Feb 2012 4:57pm
carlos50
United Kingdom 2015 Range Rover Autobiography 5.0 SC V8 Santorini Black
Will the camera from a 2010 FFRR retrofit into a 2007 MY which has a camera already but a poor one at that.
I've heard the 2010 camera is far better quality and has parking lines on it, it looks a different shape and may be a differing wiring set up hence my question?
Post #109363 25th Feb 2012 5:59pm
Stephen.125
I'm planning a how to on this, I've got a 2010 camera just waiting for the loom.
Craig has been helpful with advice as he's done it.
Post #109367 25th Feb 2012 6:27pm
carlos50
Is the loom custom made? Does the 2010 camera mount onto the spoiler of an 07 correctly or does it need mods?. Cant wait for your how to !!
Post #109376 25th Feb 2012 7:18pm
Stephen.125
Hi, it's a standard part for 2010.
You have to move/ re drill as the wire entry point fouls.
Hopefully when my loom arrives I'll be getting stuck in!
Post #109390 25th Feb 2012 10:19pm
If you need any help/pics just let me know pal... Can PM you my number if it helps...
Craig Thumbs Up
Post #109410 26th Feb 2012 12:52am
Stephen.125
See, told you he was really helpful!
Laughing Thumbs Up
Post #109431 26th Feb 2012 9:50am
Try to be... Mr. Green
Craig Thumbs Up
Post #109455 26th Feb 2012 11:41am
carlos50
Has the loom arrived, am keen to see the how to for the 2010 upgrade
Post #110664 3rd Mar 2012 12:57pm
Stephen.125
Hey Carlos.
Loom arrived. Next hurdle failed.
Need to order the plastic holder for the camera as the 2010 is a slightly different shape. Looks the same but when I came to remove and re-fit today it doesn't hold the camera.
I did check the connections though and it worked really easily.
The Coaxial cable needs the brown plastic surround removing which is easy and you need to swap the power connection from the old camera, again really easy.
I've taken the first strip down pics on my phone but need to order the other bit to make it look stock.
Also really clear to see that the old camera has a really shyt glued seam which is obviously where the moisture gets in.
On the 'dry run' the new camera looks a better resolution and has the yellow lines on it.
I'll order the holder on Monday and carry on next weekend weather permitting.
Post #110688 3rd Mar 2012 3:59pm
Page 2 of 3 <123>
