Home > Technical (L322) > Freezing Diesel |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7903 |
I'm off to the Alps on Friday & have read several reports that people have had problems with diesel freezing - even the locall bought stuff as the temperatures are that low
6th Feb 2012 8:35pm |
Thanks |
6th Feb 2012 9:00pm |
I wouldn't bother with the additive, just chuck about 15ml of acetone before filling at least half a tank up. This helps thin it out a bit.
6th Feb 2012 9:22pm |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 |
I believe you can put 5 - 10% of unleaded in your tank to stop the diesel freezing... Previously..
6th Feb 2012 10:05pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3964 |
Cars don't suffer windchill, humans do. |
6th Feb 2012 10:16pm |
I read about adding petrol / parafin / acetone - just didn't fancy any of those as it seems to work on older cars, but not sure about the TDV8.
6th Feb 2012 10:19pm |
myvatn Member Since: 20 Oct 2010 Location: Munich Posts: 80 |
hello Alistair
6th Feb 2012 10:24pm |
Cars do suffer windchill, just ask noddy about his frozen door problem
6th Feb 2012 10:50pm |
Mikeyjd Member Since: 14 Jun 2011 Location: Wrexham Posts: 543 |
The previous poster was correct. Only humans feel "windchill". It is a theoretical measurement whereby the temperature actually feels colder due to wind effects on human skin in a cold climate etc.
6th Feb 2012 10:55pm |
Doesn't the FBH, by definition, need fuel which is either frozen or not ? |
6th Feb 2012 11:02pm |
Ok not correct technical term but wind still cools compared to no wind
6th Feb 2012 11:04pm |
The diagram I've seen it doesn't use te main engine filter and can run on much thicker fuel. Diesel doesn't need I freeze to stop an engine an usually it won't, it just gets too thick FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
6th Feb 2012 11:06pm |
http://www.autos.ca/winter-driving/feature...t-your-car
6th Feb 2012 11:30pm |
What you need is a very large duvet. |
7th Feb 2012 9:40am |
