Home > In Car Electronics (L322) > Just purchased 02 Vogue and I'm a happy Man but need help!
R4NCE
2002 Range Rover Vogue Td6 Zambezi Silver
Hello everyone,
Been wanting one of these for awhile now and day eventually came.....
I love it to bits. It has a few issues that need to be addressed but hopefully with a little help from peeps on here I can get them sorted.
First Problem : Heated Front Drivers Seat - Press switch LED illuminates for 2 secs and then goes out
Second Problem : Someone has stolen the Module out the back which I think controlled Mobile Phone . There is a black plug and a aerial wire sitting there.
Any help on either topic will be appreciated,
Thanks, James.
Post #105643 5th Feb 2012 10:56pm
mjdronfield
Probably only pre wired for telephone , like mine was. Source a bmw ulf from somewhere and an antenna plus microphone and you will be good to go.
I got mine all sorted this afternoon.
Do a search on here for bluetooth and ulf .
Can't help with seat.
Welcome to the Range Rover information hub !
Mark 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #105646 6th Feb 2012 12:56am
R4NCE
hello.
Thanks for the quick reply.
Please can you give me more information regarding the bmw ulf part numbers ??? and also part numbers on the antenna and microphone? Lost at sea without a paddle.
Thanks, james
Post #105651 6th Feb 2012 10:05am
SteveMFr
Site Sponsor
I've posted a list of ULF #s here more than once. Do a search with my UN. If you can't find it, I'll re-post. No time to look at the moment.
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #105652 6th Feb 2012 10:12am
mjdronfield
Have a look on bimmernav web site, they show how to fit their kit, picture by picture........
The bay of e will be your best bet for stuff.
ULF Part Numbers ;
The newer gen the better, though more expensive. Avoid the first gen. I got one for £40 from the bay. Works, but I understand it can drop calls and things.
84 21 6 934 552 end of life 06/03 1st generation
84 21 6 938 610 end of life 10/03 2nd generation
84 21 6 934 961 end of life 03/04 3rd generation
84 21 6 950 089 end of life 06/04 4th generation
84 21 6 945 387 end of life 01/05 5th generation
84 10 6 955 522 end of life 10/05 6th generation
84 10 6 969 268 end of life 04/06 7th generation
84 21 6 958 358 end of life 05/06 8th generation
84 10 6 987 546 end of life 9/06 9th generation
84 10 6 980 130 end of life 11/06 10th generation
84 10 9 133 329 end of life 01/07 11th generation
84 10 9 145 007 end of life 05/07 12th generation
84 10 9 154 358 current production 13th generation
From various places on the net - double check before you order.........
1. ULF (Bluetooth Module) see above
2. Bluetooth Antenna (BMW part 84 50 6 928 461)
3. Mic (if your car was not already have phone system) you may as well get the upgraded one (BMW part 84 31 6 938 762).
4. Bluetooth Antenna Wire (BMW part 84 32 0 138 217) short and meant for trunk mount.
Do a google search for bmw ulf or bmw bluetooth or such like.
Start with the bimmernav site.
The 54 pin black plug will need rewiring. You can get a new plug from Audi, as they sell it loose, £2.46 inc VAT I think. Audi p/n 4e0-972-144.
Cheers
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #105656 6th Feb 2012 10:36am
Welcome.
Are you certain its the telephone box thats gone? Just wondered as your car is a 2002, maybe the previous owner removed the TV tuner as it wasn't going to receive analogue signals any longer?
If you are not sure, post a pic of what's there in the back left box and someone clever on here will be able to tell you what's missing - especially worthwhile before you buy parts.
Re the heated seat, does the passenger side or rears do the same? Have you checked the fuse? Check the connections to the seat underneath? Discovery 4 HSE
Post #105657 6th Feb 2012 10:52am
mjdronfield
I think if the older telephone TCU or even a newer ULF is in the car "Telephone" will appear as an option on the nav screen (and should work).
The TV tuner is silver and has 2 plugs, white and blue, plugged into the top of it, below the Navigation unit and slightly nearer the back seats, at floor level, in the left had side of the boot.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #105708 6th Feb 2012 5:04pm
R4NCE
ULF
Hi all,
Okay, got myself a ULF Module 13th Generation and just rang BMW for the aerial , Wire and Microphone.
Everything available except the connecting wire between aerial and ulf.
Anyone any ideas ?
Cheers, James
Post #107500 15th Feb 2012 2:12pm
jaybear
France
How much did you pay the 13Th generation ????
and where pls .
Jaybear Jaybear
2002 V8 , premier edition , 19" alloys ,
Post #107504 15th Feb 2012 2:53pm
mjdronfield
Is the wire not just a UHF lead with FAKRA connectors on ?
Can you get the part from Land Rover instead ?
Is it not there as part of the prewire, like the 54 pin connector was ? - mine was there already.
Get the blank 54 pin connector housing from an Audi dealer, as this will make the pin rewire much easier...........
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #107525 15th Feb 2012 5:54pm
R4NCE
Mark you are the man lol.
Forgot all about pre wire! Thank goodness for that started to panic a little
Thanks once again mate! Keep ya mobile on lol Thumbs Up
Post #107562 15th Feb 2012 9:36pm
mjdronfield
No problem.
The Audi part number is 4E0 972 144 if you are ordering the socket for the rewire.
For the pairing button .........
you need to short pin 32 from the ULF to ground to simulate the pairing button.
The ground pin on the ULF is pin 36, so you can use that if you don't want a switch in the front of the car.
The brown/black wire on pin 36 is the ground for the unit, so you will need to have it connected to the ULF as well when you short pin 32.
I put a "chocolate block" connector in the brown wire (don't know what the correct electrical term is !!) so I could just touch the wire from pin 32 to it, as required, without losing the ground connection to the ULF, if you see what I mean. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #107571 15th Feb 2012 10:35pm
