Home > General > It was a simple job ... what could go wrong ?
fisha
front caliper change was on the cards this morning. Had been getting crappy feeling brakes and a little binding in the mornings. I had known from a year or so ago that when I did the seals on the calipers, the pistons were showing signs of getting rough, but they were ok at the time.
2 nice calipers sitting in boxes.
Take the first side off and notice that the inner pads was quite worn, much more than the outer. Figured, there is enough there to get me going whilst I can order another set and fit them later. that was fine. Refit new caliper and go to other side.
Again, looking at it, the inner pad is worn more than the outer, but it'll do for a few more miles.
Take the caliper off and .... Censored ..... inner brake pad falls to bits Censored Censored Censored Censored Censored
Big Cry
Why cant it just be a simple job for me .... just once ! Laughing
New pads ordered. Ho Hum.
( Going to try EBC Yellowstuff this time cause of the larger tyres and towing use for the car ) V8 or else ...
Post #104552 31st Jan 2012 12:29pm
CUE99T
mate feel ye pain....I was out in the freezing cold at midnight trying to get headrests off, and almost had to strip the seat to get them out!!! The air was blue I can tell you....well frozen blue as it was -2.
anyway, gone to trimmers now for RSE... yipee!!!!! all smug in my new plug!
2021 Westminster Black D300
2013 Vogue SE - gone
Some Porsche Cayenne guff pretending to be a 4x4!!
2006 Vogue
2004 Vogue
2001 Vogue
Post #104555 31st Jan 2012 12:36pm
Andy3681
United Kingdom 2005 Range Rover Vogue Td6 Cairns Blue
fell your pain too, all set Saturday to change front and back pads all up in the air, wheels off, stripped cleaned painted hubs etc opened box wrong pads!!!! aaaaahhhhh rears to bad to go back in so trip to local factors part with cost of both just for rears. Nuts Sad Repalcement fronts on the way. Not done em on the RR before so didnt know what they looked like but supplier had Reg and Chassis number to work from.
Ended up cold and bitter.
Swoped egr out to so wait and see if that makes any difference.
Andy Mine was a blue one! Smile
Post #104557 31st Jan 2012 12:59pm
Also know the feeling well. You have my sympathy.
Latest, as documented elsewhere here, was a steering wheel change to 2010 spec.
1st attempt resulted in not being able to release spring clips on wheel hub.
2nd attempt went swimmingly until I realised late Sunday afternoon that the old 'wheel back had 4 x Torx screws that needed undoing and I didn't have any Torx drivers. Luckily, the father-in-law did and kindly drove across to come to my rescue.
Front mudflap change this weekend to remove the ones for the (soon to be for sale) side steps and on with a new set of standard 'flaps. We're staying with a very good and trusted LR enthusiast (VERY nicely modified 110 TdCi) friend this weekend, so I'm hedging my bets and have asked for his help. Si. <This is my name.
Post #104574 31st Jan 2012 2:39pm
