Home > In Car Electronics (L322) > Bluetooth Pairing Button / Connector
mjdronfield
I am trying to find out where the connector is in my car for a bluetooth pairing button.
My car does not have a phone in it, but is pre-wired.
I assume that if you put a ULF kit etc in, you use the connector that is for the eject box, to some sort of pairing button ?
Where is this connector, and what do you use for a pairing button ?
Thanks to the bay of e, I have all that parts - bar that...........
Many thanks
Mark 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #104531 31st Jan 2012 11:06am
Ajay(UK)
United Kingdom 2015 Range Rover Autobiography SDV8 Indus Silver
It all depends on your wiring loom - assuming you have a pre-touchscreen car Rolling Eyes
If you have the FFRR factory wiring loom then the 54pin black plug will need to be "modified" to suit the BMW Bluetooth ULF - The wires for the pairing button can just be connected to a momentary switch in the rear for the pairing process rather than fitting the eject box in the centre arm rest.
Here's a link to my pinout notes:
http://www.fullfatrr.com/gallery/albums/us...Pinout.pdf
If you have bought a "converted" or "modified" loom to connect to the FFRR 54pin black plug then it should already have a pairing button or pair of identifiable wires in it!
Andy. 22MY Defender 110 D250 HSE X Dynamic, Gondwana Stone.
SWMBO: 2022 RRS D300 Autobiography, Firenze Red.
Gone:2015 L405 SDV8 Autobiography, Indus Silver with Black Pack.
Gone: 2014 Discovery 4 HSE Luxury Firenze Red
Gone: 2006MY Java Black TD6 Autobiography
Gone: 2013 Jaguar XKR Convertible, Italian Racing Red with Ivory Seats
Gone: 2010MY Stornoway Grey TDV8 Vogue SE with RSE
Gone: 2008 Disco 3 HSE, Hybrid Tv + Retro-fit RSE System & DVD
Post #104543 31st Jan 2012 12:09pm
mjdronfield
Many thanks.
Yes, mine is a 2003, so pre-touchscreen.
The car was pre-wired for telephone at the factory, so I will need to rewire the 54 pin.
It's just the pairing button I'm not sure about..........
Where can I obtain the modified 54 pin loom adapters, with the pairing button ?
I thought the pairing process involved pressing the button whilst turning on the ignition or something. You would need 2 people to pair phones, as the button would need to be pressed in the boot........at the same time as the key being turned.
Am I understanding this correctly ?
Is the pairing button wired in to the "Eject Box" connections ?
Cheers
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #104621 31st Jan 2012 5:37pm
mjdronfield
Does anyone know if the pins in the infamous 54 pin connector actually pull out with the wires on ?
I am thinking of getting a new connector from Audi and just moving the required ones across in the correct place........
Many thanks
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #104983 2nd Feb 2012 3:17pm
Ajay(UK)
Yes they do! Well you can't just pull on the wires, you have to remove the black outer casing and then using a small screwdriver you can press down on the locking section of the pin itself and then give a gentle 'tug'. You can then swap the wires to their new location or remove them. When reinserting them they should click back into place Thumbs Up
Post #104991 2nd Feb 2012 3:32pm
mjdronfield
That's excellent. Many thanks.
Have just got back from the Audi dealer - the connector will be with me on Saturday.
The Audi part number is 4E0 972 144 if anyone is interested. A 54 pin female housing.
£2.46 including VAT.
If you don't have to resolder and join up wires, this job seems a little less daunting.
Historically, if you want all the pins joining together with a soldering iron - I'm your man !! Rolling with laughter
Cheers
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #105019 2nd Feb 2012 5:32pm
mjdronfield
Folks, slowly going mad here....spent over 2 hours looking at the 54 pin connector diaagrams.
A couple of queries ;
I have seen 2 charts will differing wiring - does the old pin 52 go to 21 or 19 ? and 53 will go to whats left.
19 is microphone negative, 21 is microphone shield.
L322.com changed their minds and swapped them over.
...and the piggin pairing button, I deduced that to do the button in the boot you need to put pin 32 to ground (after the rewire).
Can you use "any" ground, as the ground from the eject box is not connected to the ULF.......
Sorry for the 200 questions.
Cheers
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #105071 2nd Feb 2012 8:12pm
mjdronfield
I've just got the Bluetooth working, so to complete this thread for others, you need to short pin 32 from the ULF to ground to simulate the pairing button.
The ground pin on the ULF is pin 36, so you can use that if you don't want a switch in the front of the car.
The brown/black wire on pin 36 is the ground for the unit, so you will need to have it connected to the ULF as well when you short pin 32.
I put a "chocolate block" connector in the brown wire (don't know what the correct electrical term is !!) so I could just touch the wire from pin 32 to it, as required, without losing the ground connection to the ULF, if you see what I mean. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #105608 5th Feb 2012 5:35pm
