Home > Technical (L322) > Strange temperature gauge
Jr-auto-electrics
England 2004 Range Rover Vogue Td6 Java Black
Been looking at this at the temp gauge the last few weeks
And noticed it fluctuating when driving,
The car warms up as normal but can take a while
When driving the temp gauge moves between the
centre and the first white mark to the lower left as in cooler
I've only noticed this since doing my front conversion
Could it be that or is it more serious?
Or has any one else had the same thing
I've got an 04 td6 vogue with 64000 RANGE ROVER 04 TD6
RANGE ROVER ULTIMATE EDITION 2012
UPGRADE.
MK 4 SATNAV
http://www.flickr.com/photos/jrautoelectrics/
Post #103274 24th Jan 2012 11:45am
should'nt do that...mine goes up to halfway and stays there....your conversion seems to be the contributing factor.. ... - .- -.
Post #103275 24th Jan 2012 11:47am
Jr-auto-electrics
I'm sure it stopped centre before the conversion.
But Shirley a little bit more air wouldn't make it change so much
Because last Xmas when it was -10 it was in the middle.
Could it be something else advice needed please RANGE ROVER 04 TD6
UPGRADE.
MK 4 SATNAV
Post #103276 24th Jan 2012 12:04pm
coolant level would be my first thing to look at and any wires going to sensors etc to see if they are loose.. ... - .- -.
Post #103279 24th Jan 2012 12:18pm
Jr-auto-electrics
All checked and in good order no cracks etc.
Could it be the pump? But would this cause it to go higher? RANGE ROVER 04 TD6
UPGRADE.
MK 4 SATNAV
Post #103283 24th Jan 2012 12:34pm
not sure but i would check the engine coolant sensor, the connections to the viscous fan [does it work?] and most probably the thermostat.. ... - .- -.
Post #103286 24th Jan 2012 12:47pm
Jr-auto-electrics
Coolant sensor is in header tank and that's fine.
Viscous should work how, and where is the thermostat?
Thanks for your help RANGE ROVER 04 TD6
UPGRADE.
MK 4 SATNAV
Post #103296 24th Jan 2012 1:06pm
Fr_Raf
France 2004 Range Rover Vogue 4.4 V8 Java Black
this symptoms let me think the thermostat.
The thermostat is in the pump.
If you need to change it, I highly recommend this DIY by Joe90 :
http://www.fullfatrr.com/gallery/thumbnails.php?album=380
I'm not sure you can test it, but on old cars, I use to test my thermostat in boiling water. If it open, when water was boiling, it means the thermostat works perfectly.
sorry for the english
Post #103301 24th Jan 2012 1:40pm
Jr-auto-electrics
Thanks for the reply your English is better than mine Very Happy
Can I ask why you think it's that stat
And is this another fault with the full fats. RANGE ROVER 04 TD6
UPGRADE.
MK 4 SATNAV
Post #103303 24th Jan 2012 1:46pm
according to 'rave' its located here.. The thermostat is integral to the coolant pump housing on the inlet side of the cooling circuit.
how to is on the wiki.. ... - .- -.
Post #103304 24th Jan 2012 1:47pm
Fr_Raf
Better than your French maybe, than you English, I would like... Cool
I think It can be the thermostat, because if it stay open, all the coolant run through the engine and the radiator ; it means that It can take a while untill the temperature is correct. After that, when you drive the car, your speed contribute in coolant system by aerodynamic. If your thermostat stay open, the liquid coolant can't stay warm by staying in the motor
Post #103307 24th Jan 2012 2:02pm
Katash
England 2007 Range Rover Supercharged 4.2 SC V8 Zermatt Silver
IIRC a thermostat stuck open would create similar symptoms, coolant temp dropping as its always routed through radiator, sometimes dropping when airflow through rad is high i.e vehicle speed etc. .... Is the heater working ok? .... Could always access the hidden binnacle menu to see what the actual coolant temp is reading and check it against a thermometer reading of the coolant after its left for a while to cool and depresurise.
Post #103308 24th Jan 2012 2:04pm
Katash
Ahh beaten to it! Razz
Post #103309 24th Jan 2012 2:06pm
Katash
Post #103310 24th Jan 2012 2:12pm
Jr-auto-electrics
Are that makes sence now.
Heater works fine, I'll try putting heater on while driving at high speed to see if it drops,
Thanks
How much is a new stat? Shocked
And do I change anything else while it's apart? RANGE ROVER 04 TD6
UPGRADE.
MK 4 SATNAV
Post #103311 24th Jan 2012 2:13pm
