Home > Maintenance & Mods (L322) > led upgrade |
jaybear Member Since: 31 May 2011 Location: Marseille Posts: 156 |
Bosch
24th Jan 2012 10:03am |
VaguelyVogue Member Since: 05 Feb 2010 Location: Buckinghamshire Posts: 380 |
Has anyone got rid of the start up flicker from LED sidelights (low current bulb continuity checking) ? |
24th Jan 2012 10:22am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35436 |
i quite like the flicker and tbh i dont take much notice now.. ... - .- -.
24th Jan 2012 10:32am |
cliffy Member Since: 17 Apr 2010 Location: Surrey Posts: 556 |
There still doin the kits on eBay just found it myself
24th Jan 2012 11:03am |
bosch Member Since: 20 Jan 2012 Location: Kent Posts: 18 |
That is the same company and kit, they look good |
24th Jan 2012 11:07am |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7840 |
anyone done the indicators ?
25th Jan 2012 7:24pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6412 |
Checking for fog lights for an '02
27th Jan 2012 12:51am |
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 |
with ref to the fog lamps ant the cree led's, yes they do look brighter and throw out a bit more light but the prob is you end up with a dot of light in the middle of the fog lamp as there is no angled light from the sides.
27th Jan 2012 8:00am |
mrblonde Member Since: 24 Jan 2012 Location: Cambs Posts: 728 |
Daveo many thanks for the guide, can I be cheeky and ask a question please? Can I buy some higher powered H7 bulbs for my main beam? If so what would you recommend? just want a lot brighter, whiter light if possible |
14th Feb 2012 3:51pm |
if i may but in, i measured the voltage on my mains and it was only reading 10 volts.....i can only think that because its only supplementary lighting its not getting the full whack...
14th Feb 2012 6:10pm |
hi, i have tried led's they give the desired light,colour wise but they don't throw out much light, but as i live in London i don't need the output, saying that i have gone for a set of canbus free xenons 5000k they do give me the colour and the light output of a normal bulb..this gives you Tri-xenon as i like to call them.
14th Feb 2012 10:54pm |
Lolo Member Since: 16 Feb 2012 Location: Leinster Posts: 608 |
Hoping someone can point me in the right direction, I fitted LEDs inside and outside my RR and all is good except, I am having problems with the approach lamps on the wing mirrors as someone here mentioned they had too , one will work until the two are connected. I beleve Resistors are needed etc, but I have canbus LEDs, are these not built in resistors?
18th Feb 2012 7:01pm |
just a guess but try turning the bulbs around in the holder..might be different polarity's working against each other.. ... - .- -.
18th Feb 2012 8:59pm |
hi, you dont need the can bus warning on these bulbs.. but i had the same problem when i changed my ones to leds, i solved it by using a resister on both sides to increase and even out the load.. V8 facelift Range Rover Autobiography 22" wheels.
18th Feb 2012 11:30pm |
