![]() | Home > In Car Electronics (L322) > [SOLVED!] '02 Non Touch Screen too Dim with Video Input? |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6419 ![]() ![]() |
Can't find a physical fix for this with the kit I have attached so does anyone know about anything internal?
I've just found this over on the bimmernav forums
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35611 ![]() ![]() |
there are these codes,
Yes, but this is a different one! Will try out tonight. .
It's there on an FFRR too!
Can it be added to the wiki? (Suggest add the bimmernav link too as this has a good howto on all the functions) . Experience is the only genuine knowledge, but as time passes, I have forgotten more than I can remember ![]() Volvo V70 P2 2006 2.4 Petrol 170bhp Estate SE MG Midget Mk1 1962 Previous: L322 Range Rover TDV8 3.6 2008; L322 Range Rover TD6 3.0 2002; P38A Range Rover V8 1999 |
added to the wiki joe. |
@ daveo Had crossed my mind. Camcorder ? Don't have one |
i will give that secret menu ago as when i done the software upgrade on the nav unit i am sure the screen went darker so that may help, but will be changing my screen soon for the later touch screen unit. V8 facelift Range Rover Autobiography 22" wheels.
Dogman Member Since: 10 Dec 2010 Location: UK Posts: 174 ![]() ![]() ![]() |
Might be worth checking if the converter is definitely RGB & not YUV (or vice versa) as this can cause issues if you're just working on the basis of 3 coloured phono connectors.
@ Dogman
Cool Joe90, Carpc does sound good |
joe.. did the adjustment make a difference on the standard screen, did it get brighter V8 facelift Range Rover Autobiography 22" wheels.
question joe, would it not be better to use an andriod tablet rather than a netbook...mounting it would be much more convenient.. ... - .- -.
@ daveo
