Home > Technical (L322) > TD6 wont start, asking for code.... Help |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35247 |
should'nt need a code to start , even the radio doesnt require one..
20th Jan 2012 4:40pm |
speedymarktd6 Member Since: 20 Nov 2008 Location: Worcestershire Posts: 727 |
Has the battery gone flat in your fob and its not recognising your key onto no6 Range Rover
20th Jan 2012 4:43pm |
Rosco Member Since: 20 Jan 2012 Location: Beyond the wall. Posts: 2573 |
thanks for replies, would key battery account for 'CODE ----' ? Car battery is fully charged, everything works apart from starting!! Have spoken to LR and dealer who have no suggestions apart from 'bring it in' ! |
20th Jan 2012 4:47pm |
Richcl Member Since: 23 Sep 2010 Location: Tewkesbury, Glos Posts: 1011 |
"Bring it in"= Kerching!!! |
20th Jan 2012 4:54pm |
bang on !! |
20th Jan 2012 4:57pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3969 |
On a td6 the obd has a code function that is an "engine interlock code".
20th Jan 2012 5:34pm |
I have tried emergency deactivation but unable to deactivate alarm when it goes off, doesnt recognise key however still had the problem when key worked central locking etc. |
20th Jan 2012 6:56pm |
How did you do the deactivation?
20th Jan 2012 7:02pm |
In the manual under computer controls it says to deactivate interlock code - 'disconnect earth terminal for 1 minute then reconnect, the alarm will sound and must be deactivated with remote.' This apparently resets something!! However not worked for me, I know it must be something simple but have posted on numerous Forums and nobody seems to have encountered it before, can't be the only FFRR with this issue, been sitting now for 8 months as I work in the Channel Islands and its looking a bit sad |
20th Jan 2012 7:17pm |
I'm wondering if your problem is linked to the immobiliser function and if so whether it could be cleared with one of the diagnostic tools available, Whereabouts in Scotland are you? |
21st Jan 2012 11:12am |
I am in Ayrshire, about 20 miles south of Glasgow |
21st Jan 2012 12:17pm |
Unfortunately you are a bit too far from me, the closest I get is the M74 and then over to Edinburgh every now and again.
21st Jan 2012 12:57pm |
Thanks
21st Jan 2012 1:05pm |
Sorry I don't know how to bypass it, bit more complicated than a Disco that I could do. |
21st Jan 2012 1:15pm |
