Home > Maintenance & Mods (L322) > Engine Bay Light
A1GSS
Engine Bay Light
I was surprised to find (when broken down in the dark recently with my alarm going off) that there is no light in the engine bay.
Anyone done a mod to wire in some lighting? Graham
____
Gone: 10MY L320 RR Sport HSE, Ipanema Sand
Gone: 20MY Jaguar iPace HSE, Silicon Silver
Gone: 17MY RR Evoque SE Tech, Loire Blue
Gone: 08MY Discovery 3 XS, Stornoway Grey
Gone: 07MY FFRR TDV8 Vogue, Stornoway Grey
Post #101766 14th Jan 2012 11:29pm
JustinP
United Kingdom 2006 Range Rover Vogue SE Supercharged Java Black
There's a torch in the venture cam.
Gone - Range Rover Supercharged 2006
Post #101780 15th Jan 2012 9:13am
A1GSS
No venture cam. I assume the previous owner took it... I do keep a torch in the car, but would like to rig up a "proper" under-bonnet light. Graham
____
Post #101782 15th Jan 2012 9:50am
It should be simple enough with modern LED lighting and a direct feed from the battery via a fused link. You would need to check if it could be attached to the existing under bonnet alarm switch or if a separate switch was required.
Post #101785 15th Jan 2012 10:04am
Glideman
Location: Stood next to a broken down Range Rover in Darwen
United Kingdom 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
The times these things break down they should have a seat & a flask Laughing Big Cry Range Rover 4.4 V8 Vogue
Post #102685 20th Jan 2012 5:29pm
You could use a simple tilt switch for the light instead of getting involved in the bonnect switch or fitting another switch.
Post #102739 20th Jan 2012 9:00pm
A1GSS
Yes. I've just bought some LED festoons from HIDS4U (D3 sponsor). I'll get a fitting from a scrapper and see what I can cobble up Graham
____
Post #102745 20th Jan 2012 9:10pm
