![]() | Home > Maintenance & Mods (L322) > Maxxraxx Bike Rack Question |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7975 ![]() ![]() ![]() |
Having contributed to your original thread and as a MaxxRaxx owner, I'm not sure I would...... unless you need to tow at the same time. That Halfords one looked easier |
CG-SC Member Since: 06 May 2011 Location: Falkirk Posts: 528 ![]() ![]() |
Thanks Alister, you've got me thinking now ....... |
Johnte Member Since: 23 Aug 2010 Location: North Yorkshire Posts: 741 ![]() ![]() |
I got this one from Halfords - BIKE RACK
Mutley Member Since: 29 Jun 2011 Location: Reading, Berkshire Posts: 172 ![]() ![]() ![]() |
Hi guys this is the rack I have fits to the towbar I have had things like the one your looking at but this is far better & easier but it's expensive plus you don't have to remove to get the boot open it slides down to allow access see the video on the site
Nick Ground Member Since: 27 Dec 2011 Location: Dorset Posts: 584 ![]() ![]() ![]() |
Well I have had my Maxxrax for years now. Used on P38, L322, Freelander so its a built to last piece of kit. Have the extension to allow for towing at same time too. However, if you buy one remember that they will charge you loads for a swan neck attachment if you have the detachable RR bar because they insist on a professional to install it. Also if you tow a caravan with an Alko stabiliser you will need to order the wider bracket for the standard bracket.
Well I ordered my Maxxraxx today so looking forward to receiving it. I fitted the Westfalia electrics at the weekend so all ready to go....
They go inside the upper section of the boot - thees a strap with a kind of rubber coated cylinder on one end - the cylinder goes inside the boot an when pulled tight touches the trim to stop the strap coming out of the gap - if that makes sense.
So if i am understanding you correctly, it goes around the upper tailgate hinge ?.... Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather..... |
Yep - I think I ran mine round the side rather than over the plastic spoiler, but can't actually remember as it's been a few years.... |
