Home > Technical (L322) > FBH Fault....
Page 2 of 3 <123>
A1GSS
kingpleb wrote:
... Took me 2 days on my own to do mine...
The FFRR FBH or the Xantia Matrix...? Graham
____
Gone: 10MY L320 RR Sport HSE, Ipanema Sand
Gone: 20MY Jaguar iPace HSE, Silicon Silver
Gone: 17MY RR Evoque SE Tech, Loire Blue
Gone: 08MY Discovery 3 XS, Stornoway Grey
Gone: 07MY FFRR TDV8 Vogue, Stornoway Grey
Post #97915 15th Dec 2011 11:09pm
the xantia heater matrix Sad
Post #97927 15th Dec 2011 11:47pm
A1GSS
Phew. Graham
____
Post #97933 16th Dec 2011 12:21am
I'll check RAVE over the next few days and see what it quotes but can't imagine its a big job, probably 2 spanners on the haynes scale Smile
Post #97935 16th Dec 2011 12:36am
A1GSS
Laughing VG. I have a Haynes tea mug and lots of spanners so I'm probably good to go.
Also have owned 10 hydraulic Citroens, so "modern" crap like Xantias, pah. 2 days. How hard can it be. Quote from Haynes manual for Citroen GS 1220:
Quote:
"Remove the fan".
2 days later.... Big Cry Graham
____
Post #97937 16th Dec 2011 12:42am
SteveMFr
Site Sponsor
There is nothing in the RAVE on repairing the FBH. I just posted most of the relevant info in the 'Have I got an FBH' thread in general.
Graham, here are the relevant tech docs in English. Don't be put off if it looks like a lot. It is a rather simple device. You just have to weed through the irrelevant info first.
http://www.techwebasto.com/heater_main/tec...63378A.pdf
http://www.techwebasto.com/heater_main/hea...g_Tree.pdf
and the main menu for the docs
http://www.techwebasto.com/heater_car_light_truck.htm
From my past experience here is a list of most common FBH problems (though my experience is based on the older generation of FBH. Should be close to the same):
- bad glow plug (continuity test)
- bad thermal overload breaker (continuity test)
- improper fuel mixture (the mixture is metered by both the fuel pump (precise 'dosage-pump') and the combustion air pump).
- thermal overload due to bad coolant pump
In the first 2 cases the FBH will not even try to run whereas in the latter 2 it will start and shut down without producing any heat.
I'd also contact Webasto and ask who does their FBH repairs in the UK. Here on the mainland it's all Bosch Service Centers (amongst others).
http://www.webasto.co.uk/home/en/html/homepage.html
Let me know if I can be of help if you do attempt the repair yourself.
BTW, the FBH function for the IIDTool is finished. Rolling Eyes We are confirming it in the coming days starting with my RR this evening (as I leave for the US on Sunday).
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #97948 16th Dec 2011 8:45am
A1GSS
Thanks Steve, really helpful. I'll take a look. Graham
____
Post #97950 16th Dec 2011 9:01am
A1GSS
Right. Bit of good news...
I had Webasto take a look at the fault codes etc; their diagnosis is a faulty ECU or faulty car signalling. As a result, Lookers have done more diagnosis and concluded it has to be the ECU, so Warranty Direct guys have accepted responsibility, and the car's now booked in to have a new heater fitted... costs covered by WD.
Happy Christmas. Very Happy Graham
____
Post #99056 23rd Dec 2011 11:26am
boffhead
I'm glad you're getting this sorted. It was the ECU that failed on mine too. I spent a lot of money in determining this so my advise to anyone experiencing problems with FBH is to just get a new or scrap one..... Saves a lot of titting about!
When mine stopped working I had the fault codes read (£90) and was informed it was the glow pin down to earth so i removed it from the car to get overhauled at local webasto man. He replaced the combustor, de-coked and tested it (£350). He did say that he was unable to test the ECU as this was not a generic Webasto ECU. When fitted back onto the car it still didn't work, so because I couldn't hear the fuel pump I bought a new one (£45). New fuel pump fitted and the bloody thing still didn't work.
Getting really frustrated, I bought another unit from a breakers (£70), gave it an overhaul with the new parts from the duff FBH, refitted to car and hey presto it fired first time. It did shut down after a couple of minutes, but on the third attempt it ran for the full 30 minutes and has run when ever its been called for ever since.
One thing that I have noted since playing around with this is that when I use the remote to operate the FBH it only heats the cabin...... Not the engine. Don't know how it operates below 5c when called for automatically.
That's my story anyway.
Chris
Post #99079 23rd Dec 2011 1:49pm
Renegade2
Hi Boffhead, is it a big job removing the unit?Mine needs looking at and ceratainly not going to main dealers. Mine does not seem to be firing at all. I am going to do the disconnect the battery for 10secs to see if this does a reset but failing that it will need to come out.
Post #99080 23rd Dec 2011 1:58pm
A1GSS
Removal looks reasonably straightforward (instructions posted on another thread somewhere), but once it's out you've got coolant pipes and a fuel pipe to worry about if you want to use the car.
CAV Automotive in Preston do a service, I rang them up - very helpful, but as boffhead says the ECU isn't part of their service.
http://stores.ebay.co.uk/CAV-Automotive-Ltd?_trksid=p4340.l2563 Graham
____
Post #99084 23rd Dec 2011 2:12pm
A1GSS
Car back from Lookers last night. At the eye watering cost of almost £1400 I have a new FBH and a toasty warm car this morning. Yay! All good.
All I have to achieve now is receive the repayment from Warranty Direct. They covered this fault because it was proven by Webasto Tech Services and LR's technical bods that the "failure to fire" problem was down to signalling faults caused by a faulty FBH ECU, which happens to be built into the FBH itself.
The ECUs are covered by the WD warranty, so to replace the ECU I had to have a new FBH. Very Happy Graham
____
Post #100523 6th Jan 2012 3:19pm
simon1233
Excellent news Graham Thumbs Up
Post #100524 6th Jan 2012 3:23pm
Renegade2
SteveMfr you do seem to have an excellant knowldge of the FBH unit but mine is quite puzzling.
On my touchscreen i have the timed climate which states on it 30 minutes of venting or heating and you can set two diffrenet times in the one day, i also have a manual softkey. When i set it to timed you can hear the fans power on but FBH (when temp below 16C, as above it vents only?) when i select the manual softkey nothing happens not even fans.
Howvever i know that the FBH is working as yesterday it was cold first thing in Cardiff and when i started the car i heared the familiar noise on left on side (sounds like a bee farting!!) so i opened the bonnett and could hear the FBH starting up and then the jet turbine sound along with exhaust fumes.
So kit works when the engine is on and at 5c or below but not when selected via timed or manually? Can anyone help solve this little issue for me? Dont really want to go to dealer as we do not exactly see eye to eye.
Thanks in advance
Post #100929 9th Jan 2012 3:50pm
Pitouille
Switzerland
start and stop
Hello,
I have also a problem with the FBH fitted in my Disco 4 SDV6 ( bought 2 months ago). I can activate it either
from the touch screen or via the RC, it starts 'normally" but automatically shuts down after 4 or 5 minutes without having heated anything inside the car. On my case I suspect a battery discharge problem, it is like if it was the disco that would stop the Webasto, to prevent an excessive discharge of the battery. In fact when I turn on the engine after a heating failure, I get a message on the screen "timed climate not available, please check your fuel level ( which is ok) battery charge may be low " . During one of the attemps after another faulty FBH start, I even once got the red battery light on the dashboard and could not start the engine at all, I turned off all auxilliary equipments and this allowed me to start the engine. To me the battery is not powerfull enough to supply the heater during its operation ( or does not charge properly ? ). Does anyone ever experienced the same problem ?
Thanks in advance Land Rover, official recovery car for Japanese 4x4 vehicules.
Post #102293 18th Jan 2012 5:21pm
Page 2 of 3 <123>
