Home > Technical (L322) > Ongoing engine Fault Problem |
piecost76 Member Since: 19 Jul 2010 Location: Nr Sevenoaks, Kent Posts: 296 |
Hi Steve,
12th Jan 2012 9:18am |
33CHINACARS Member Since: 14 Apr 2011 Location: Tyrendarra, Victoria, Australia Posts: 381 |
Yep check Battery & connections. If thats not it sorry cant help any more
12th Jan 2012 3:29pm |
SteveB Member Since: 12 Jan 2012 Location: Kent Posts: 56 |
Just got another call from garage who in turn have had another call from land rover technical. They now suspect that the replacement injection pump may have developed a fault as well. So it will be in again to have more tests and a replacement injection pump to the replacement pump already fitted. Oh joy
12th Jan 2012 5:22pm |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1393 |
Sensor replaced leading to same same error ? The probably of a newly fitted sensor being crap ( whilst not impossible ) is outweighed by the probability that the sensor is good and that what the sensor is connected to is now the next link in the chain to be looked at.
12th Jan 2012 5:59pm |
bozmandb9 Member Since: 06 Dec 2010 Location: Wallingford, Oxfordshire Posts: 1020 |
I still think it's your battery, how old is it? Did they give you the voltage figures? Range Rover-less at the moment - Pining! |
12th Jan 2012 6:46pm |
Thank you all for your advice and guidance. I made it home without incident tonight, although the ideal ducked a couple of times when pulling up at lights but engine didn't stall. I have the car booked in for the 23rd Jan so I will get all the fault codes when I drop it in.
12th Jan 2012 7:12pm |
Battery is the original one from October 2006 Steve B
12th Jan 2012 7:18pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35426 |
that battery will need changing steve... ... - .- -.
12th Jan 2012 7:20pm |
Knew it, I bet it's the battery! Unless they really know Land Rovers, anybody will test one and say it's fine, which it may be for starting the car, but the Range Rover is very demanding on it's battery, and very intolerant of 5 year old batteries! I may be wrong, but 5 years is ALWAYS the time when these batteries fail. Ask me how I know, then ask 90% of the other forum members how they know! Range Rover-less at the moment - Pining! |
12th Jan 2012 7:51pm |
Still inclined to think the injection pump may have a problem as I went for a drive tonight and when I pull up the ideal seems lumpy nearly cutting out a couple of times and when driving from standstill the initial acceleration is a little lumpy as well. When at speed all seems ok.
12th Jan 2012 10:08pm |
Would you believe it, a 20 mile drive to work this morning in the dark and not a single problem, in fact driving was a pleasure, smooth and powerful as it should be. Loving my RR again, but for how long I dont know.
13th Jan 2012 1:01pm |
Hi Steve,
13th Jan 2012 3:00pm |
speedymarktd6 Member Since: 20 Nov 2008 Location: Worcestershire Posts: 727 |
Im going to say battery aswell i had a battery on mine that i knew was faulty it had a dead cell and would not hold charge i deliberatly took it into land rover for a free check and they said it was fine just needs a charge
13th Jan 2012 3:13pm |
I am near Maidstone in Kent, is that close?
13th Jan 2012 3:34pm |
