Home > General > Fuel filler driving me potty!
More times than not, when I go to fill up the TDV8 it takes an absolute age because the fuel filler keeps on clicking off, as if the tank is full! I've tried turning the nozzle in different directions buts its really annoying.
Does anyone else have this? Is it an issue with the filler neck that needs dealership attention?
Thank GOD it's not a SC and I only have to do this every 500 miles.... Big Cry Discovery 4 HSE
Post #10140 30th Dec 2009 4:19pm
Mostly down to when your filling up the air is being pushed out which automatically sets off the pumps cut off system.
Do you put the nozzle fully in ....
Or before you fill up, take off the diesel cap and try to shake the FFRR slightly to dispel any built up gas or air in the tank.
Every 500 miles, alright for some folk .............. Whistle
Post #10142 30th Dec 2009 4:33pm
itguy
2006 Range Rover Vogue Td6 Cairns Blue
I presume this is different to your td6 then? My td6 is no problem to fill.
Have you tried just putting the nozzle just into the filler on the first 'notch' ? I never push it all the way in. FFRR TD6 06MY. Cairns Blue, Blue Hide. LR 7 Spoke 20" Wheels, S/C Grill and Vents. Privacy Glass and Side Steps
Post #10143 30th Dec 2009 5:30pm
Never had a problem with the TD6, but that didn't have the fuel gaurd fitted either.
Why do we need saving from ourselves Censored , I was always happy with a big bore filler pipe....
Is the fuel filler pipe made of a flexible material that could somehow be kinked or creased resulting in impedance of fuel flow? Discovery 4 HSE
Post #10144 30th Dec 2009 5:36pm
JMC
Scotland 2012 Range Rover Westminster TDV8 Orkney Grey
Turn the pump handle through 180 degrees and use it 'upside-down'. Works for me! I think the mis-fuel device in the filler neck makes for a difficult fill at the best of times. Rolling Eyes The older I get, the more I realise that people confuse wrinkles for wisdom Smile
Post #10146 30th Dec 2009 5:54pm
Real RR
There is a "Difficult to Fill Fuel Tank" TSB on GTR http://www.landrovertechinfo.com. Can be found under Technical Bulletins at Reference: LTB00135v2. Don't know what it contains as I have not accessed it.
Post #10156 30th Dec 2009 9:12pm
The doc
2008 Range Rover Vogue TDV8 Java Black
Reset the fuel guard just incase Thumbs Up '09 Freelander 2 TD4 HSE Auto for the Mrs
Using the works Fiesta 1.6 TDCI Sport Van - CHROME FREE THOUGH
Searching for a nice E63 AMG or S8 V10 to replace my "wonky" TDV8
Post #10160 30th Dec 2009 9:40pm
Yup, found this:
Title: Difficult to Fill Fuel Tank
Type:
LM - New Range Rover - All Years - Technical Bulletins - Fuel System
Name / Part No: LTB00135v2
Info Type: Service Bulletins
Version No: 2
Date Uploaded: 09 Dec 2008 Discovery 4 HSE
Post #10166 30th Dec 2009 11:39pm
