![]() | Home > General > Range rover tdv8 2007 light power steering |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35508 ![]() ![]() |
check the tyre pressures |
Stingclive33 Member Since: 07 Jan 2012 Location: Rye Posts: 28 ![]() ![]() ![]() |
I have just had new tyres and brake pad/discs fitted and tyrevpressuresvare spot on, I do have to confess that the previous owner fitted storm 22" wheels/tyres. I no these are looked down on and I might fit some 19" wheels from a previous 2007 RR sport. |
swirl80 Member Since: 11 Dec 2011 Location: Northumberland Posts: 46 ![]() ![]() ![]() |
is it only light at slow speeds? |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16315 ![]() ![]() ![]() |
Variable power steering valves are the normal culprit if steering gets very heavy or very light and not too expensive to fit either...
The steering does get firmer the faster I go and above 50 it feels right. It's dry light when stationary up to 40 |
Sorry typo it should read very light |
would that be the servotronic valve craig?
Yes Stan, the same on all models i think??? We had one that would go from lock to lock with the flick of a finger... Very odd feeling.
so clive, consensus is that your servotronic valve needs replacing..
Thanks very much, I will be off to get my servotronic valves replaced, when you mentioned that they (is that two) are not expensive, in what sort of ball park will the cost be in? |
Oh Craig I see you have 22" beasties on yours, I have had every body telling me to take mine off what do you think? |
These...
I love the look and will keep mine, although all the negative jibes did make me think my light steering was a result of the 22's, so now I feel much happier thanks to you guys |
Your welcome... Let us know if its cured...
