Home > General > Range rover tdv8 2007 light power steering |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35160 |
check the tyre pressures ... - .- -.
7th Jan 2012 10:39pm |
Stingclive33 Member Since: 07 Jan 2012 Location: Rye Posts: 28 |
I have just had new tyres and brake pad/discs fitted and tyrevpressuresvare spot on, I do have to confess that the previous owner fitted storm 22" wheels/tyres. I no these are looked down on and I might fit some 19" wheels from a previous 2007 RR sport. |
7th Jan 2012 10:55pm |
swirl80 Member Since: 11 Dec 2011 Location: Northumberland Posts: 46 |
is it only light at slow speeds? |
7th Jan 2012 11:18pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16232 |
Variable power steering valves are the normal culprit if steering gets very heavy or very light and not too expensive to fit either...
7th Jan 2012 11:23pm |
The steering does get firmer the faster I go and above 50 it feels right. It's dry light when stationary up to 40 |
7th Jan 2012 11:31pm |
Sorry typo it should read very light |
7th Jan 2012 11:34pm |
would that be the servotronic valve craig?
7th Jan 2012 11:35pm |
Yes Stan, the same on all models i think??? We had one that would go from lock to lock with the flick of a finger... Very odd feeling.
7th Jan 2012 11:43pm |
so clive, consensus is that your servotronic valve needs replacing..
7th Jan 2012 11:45pm |
Thanks very much, I will be off to get my servotronic valves replaced, when you mentioned that they (is that two) are not expensive, in what sort of ball park will the cost be in? |
7th Jan 2012 11:52pm |
Oh Craig I see you have 22" beasties on yours, I have had every body telling me to take mine off what do you think? |
7th Jan 2012 11:55pm |
These...
8th Jan 2012 12:10am |
I love the look and will keep mine, although all the negative jibes did make me think my light steering was a result of the 22's, so now I feel much happier thanks to you guys
8th Jan 2012 12:27am |
Your welcome... Let us know if its cured...
8th Jan 2012 12:29am |
