![]() | Home > General > Tailgate opening height? |
Almost exactly 2000mm |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6745 ![]() ![]() ![]() |
Thanks, I'll go and check mine.
Yes and on gravel. |
Maybe it wasn't my imagination then, mine is 1910mm! |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 ![]() ![]() ![]() |
Maybe their both |
Could be that Autobiography badge you stuck on the back |
I don't have an AB badge on the back, that was the previous owner, but maybe 5 years of the extra weight might have f |
We should measure from the lower tailgate to the upper tailgate somewhere, either from the catch or the corners to eliminate uneven ground / EAS heights etc, and also with the same age vehicle |
That sounds like a good plan! |
Top of bumper, the painted bit, to bottom edge of upper tailgate, 1350mm.
Mine measure 1310mm, so not quite as bad as it first appeared........... |
