Home > General > Tailgate opening height?
Can someone do me a favour please?
For some reason, I get the feeling the top door of the tailgate isn't opening as high as it used to. Maybe it's just my imagination, but I don't want to force it higher and Censored up the struts, so can someone measure the distance from the ground to the tailgate edge when it's fully open please?
Many thanks in advance! Thumbs Up Got - 2017 SDV8 Autobiography in Loire Blue
Post #100630 7th Jan 2012 12:42pm
Almost exactly 2000mm
Post #100641 7th Jan 2012 2:20pm
Thanks, I'll go and check mine.
Is that with the suspension in "normal" setting? Got - 2017 SDV8 Autobiography in Loire Blue
Post #100642 7th Jan 2012 2:25pm
Yes and on gravel.
Post #100644 7th Jan 2012 2:37pm
Maybe it wasn't my imagination then, mine is 1910mm! Whistle Got - 2017 SDV8 Autobiography in Loire Blue
Post #100647 7th Jan 2012 2:45pm
Maybe their both Censored ? Whistle Rolling with laughter [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #100649 7th Jan 2012 3:03pm
Googsy
Could be that Autobiography badge you stuck on the back Whistle Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #100665 7th Jan 2012 4:32pm
I don't have an AB badge on the back, that was the previous owner, but maybe 5 years of the extra weight might have f Censored d the struts! Thumbs Up Got - 2017 SDV8 Autobiography in Loire Blue
Post #100668 7th Jan 2012 4:49pm
We should measure from the lower tailgate to the upper tailgate somewhere, either from the catch or the corners to eliminate uneven ground / EAS heights etc, and also with the same age vehicle Wink .
Post #100750 8th Jan 2012 2:00am
That sounds like a good plan! Thumbs Up
I did have it in my mind that there were a fair few variables that needed eliminated. Got - 2017 SDV8 Autobiography in Loire Blue
Post #100771 8th Jan 2012 11:20am
Top of bumper, the painted bit, to bottom edge of upper tailgate, 1350mm.
In the centre, with no wind. Smile No sun either.
Post #100780 8th Jan 2012 12:19pm
Mine measure 1310mm, so not quite as bad as it first appeared........... Rolling Eyes
Thanks for the info! Thumbs Up Got - 2017 SDV8 Autobiography in Loire Blue
Post #100789 8th Jan 2012 1:11pm
