Home > Technical (L322) > SUSPENSION FAULT! WHAT TO DO? |
The doc Member Since: 25 Mar 2007 Location: In car hell :-( Posts: 425 |
I have this happen a lot on X5's when I've been working on them - there is a fuse in the o/s/r that somtimes needs pulling out and pushing back in - should be in your manual - worth a go and free '09 Freelander 2 TD4 HSE Auto for the Mrs
26th Dec 2009 11:15am |
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 |
hi, start the car and let it idle, then turn the stearing full to the left and then to the right and back to the left, it resets it.. it worked for me...
26th Dec 2009 11:52am |
RRV Member Since: 05 Oct 2009 Location: Midlands Posts: 648 |
Envoy,happy Xmas mate.
26th Dec 2009 12:20pm |
andyw Member Since: 15 Oct 2009 Location: united kingdom Posts: 160 |
I had that fault before that my EAS was slugish and slow and eventualy gave up and turned off. trip to the stealers some time later and all fixed EAS is now like a tric car with the tric suspension EAS is now very fast and no pros so far
26th Dec 2009 3:52pm |
Stoich Member Since: 21 Dec 2009 Location: Stornoway Posts: 36 |
Got this from the manual
26th Dec 2009 4:05pm |
ENVOY Member Since: 25 Mar 2007 Location: up a track in the middle of nowhere Posts: 239 |
Thanks guys for all your suggestions, advice and help. No good so far, have tried Daveo's suggestion and had no joy also had a look for a fuse and cant find one! will try disconnecting the battery tomorrow and see if that does anything.
27th Dec 2009 10:04pm |
http://www.fullfatrr.com/forum/topic229.html?highlight=suspension |
27th Dec 2009 10:22pm |
Well i took the compressor cover off in the boot, couldnt find any sort of valve matching Micks description so i took both solenoid valves apart and had a general look around but could not find anything that looked amiss, put it all back together disconected the battery for half an hour, reconected it and guess what............................................ no f g difference at all, still got the same fault
28th Dec 2009 2:54pm |
XXXAngelXXX Member Since: 25 Mar 2007 Location: Stuttgart Posts: 4989 |
All my spelling errorz are belong to me!
28th Dec 2009 3:12pm |
jayzee Member Since: 14 Oct 2009 Location: UK Posts: 342 |
Gold thimble sized valve? It may have been removed at some point, as mine was. |
28th Dec 2009 11:41pm |
Took the car to the garage today to get the suspension sorted, they pluged in the computer and the fault said "not enough air getting to the reciever" They reckon it is down to the very cold temp! whatever the reason its ok now and it works fine! At least it didnt cost me a small fortune |
4th Jan 2010 10:52pm |
Thank goodness for that - had me worried for you mate '09 Freelander 2 TD4 HSE Auto for the Mrs
4th Jan 2010 11:08pm |
