Home > Technical (L322) > Lower Tailgate Electrics
Page 2 of 3 <123>
duckworthparts
Site Sponsor
fan? is that my new nickname now Rolling Eyes Laughing You can paypal direct using - www.paypal.me/duckworthparts
Please supply your full name address when sending a paypal payment.
https://www.facebook.com/duckworthparts
www.duckworthparts.co.uk
My Direct Line: 01673 849873
Email: robin.hall@duckworth.co.uk
Supplier of Genuine Land Rover & Jaguar Parts For All Models
Post #96502 6th Dec 2011 4:55pm
Lol we're all fans of Dan the man lol!!
Auto text on iPod ain't as good as it should be Smile
Post #96504 6th Dec 2011 5:08pm
DAM and double DAM.
I've now replaced,
- Lower tailgate wiring loom
- LH + RH Actuator units
- Relay
- Fuse(wasn't blown anyway)
And still can not get anything to happen when I press the dammed button to unlock them Sad
Is there a reset procedure or something i am missing as i cna't find anything in RAVE about it other than the relay relies on a message from the BCU across Fuse 16 to activate the Tail Door Relay.
The only thing i notice is that the new relay i have is 4 pin, yet the place it goes seems to be 5 pin... Dont get me wrong it fits in just fine, im just wondering if something is missing.
I guess i need to get a volt meter and starting checking the whole lot Sad Wish i had an MSV2 now as no doubt i could just force the signal from the BCU to test it...
Post #99986 1st Jan 2012 12:06am
Anyone?? Sad
Post #100212 3rd Jan 2012 9:05pm
Are you getting a voltage reading at the switch or actuators?
Post #100213 3rd Jan 2012 9:07pm
I haven't got that far yet im afraid Sad It will likely be next week when the nipper is out that i can try that.
What kinda voltage should it be as i think my 9083 is toast so was going to rig up a test bulb and see if it worked? Just a low power Maglite bulb Smile
Post #100214 3rd Jan 2012 9:12pm
I would expect to see 12v at the switch. Also I would have checked this before buying all the new parts
Post #100234 4th Jan 2012 12:14am
The loom was shot and had seen some bodgework before so i had to replace it as i don't like untidy cabling Sad
Post #100238 4th Jan 2012 2:39am
Well my 9083 is on the bay so i ordered a cheap draper unit from amazon for £12 and it seems turdy and OK enough so will be giving the units and good going over tomorrow as should only take about 10 minutes to take the panels off and connect to each one.
May keep the croc clips from my 9083 though and the test leads as they are MILES better than the cheap ones i got with the draper and croc clips are soooo useful Smile
manual release has become so tedious as work with my 2nd job has picked up its a pain for loading and unloading and even for the kids stuff like playing out in the snow and hiking Sad FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #110179 29th Feb 2012 10:18pm
Well I've now tested at the switch and actuators and no power at all. I do notice the switch has 3pins but the cable is only 2pins at the plug but still it goes open circuit when activated Sad
I think the switch part of the loom goes forward into the car as I'm sure it tells the canbus to then activate the relay Sad
Where can I go now as I'm sure it's something simple but I've checked the fuses!!! FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #111513 7th Mar 2012 4:34pm
Mikeyjd
Wales 2003 Range Rover SE Td6 Zambezi Silver
My lower tailgate stopped working a couple of days ago. The motor doesn't sound when I press the button but the tailgate will open manually of course.
This morning, I took the fuse out to check it, when I refitted the fuse, the motor fired and unlocked the catches. I have tried it a few times, the button on the tailgate does nothing but taking out and refitting the fuse operates the locks. Any thoughts on what the problem is? Faulty switch or a relay or what? No longer FF owner but still interested. Present car Jaguar XE
Previous car Td6 SE
Previous LR- Disco 300TDi Auto
Post #114737 25th Mar 2012 12:43pm
Mikeyjd
Sorted now.
My problem was caused by the black release button being stuck down. I played around with it for a while and it seems fine now. Simple job - simple solution Very Happy No longer FF owner but still interested. Present car Jaguar XE
Previous car Td6 SE
Post #114739 25th Mar 2012 1:11pm
Thanks mikey, think I've tried this but I'll give it another go before it goes to an indie for its wheel bearing this week an I ask them to check the bcm incase it's totally locked out from the previous owners wiring attempt...
It's got a new switch, wiring loom for the lower tailgate, and new latch motors, and new relay... FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #114748 25th Mar 2012 5:47pm
Glad yours is fixed now though and a simple enough fix! FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #114749 25th Mar 2012 5:48pm
Is anyone playing around with their tailgate at all and able to run some electrical tests on their release button and the wiring to it at all??
The local garage tested it earlier and think that the switch is at fault as when its pressed the BCM sees nothing but no fault is logged against it Sad
The plot thickens and with it being up for sale i need to repair it Very Happy FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #115211 28th Mar 2012 12:56pm
Page 2 of 3 <123>
