Home > Maintenance & Mods (L322) > decating a ff v8 m62
klf400
hi guys thinking of decating my ff l322 m62 v8 along with an lpg system , i have decatted p38s with no problem as they only have precat sensors but the l322 has upstream and downstream sensors , i know the new mot rules may hinder this but i will cross that bridge when i come to it
i would be very gratefull of any help on this ssubject 1990 3.5 v8 defender
2000 4.6 v8 30th anniversary prins lpg
2004 4.4 v8 vogue prins lpg
2011 4.4 TDV8 Vogue
faultmate extreme
rsw allcoms
Autel 906BT
Gap iiD tool
Post #100058 2nd Jan 2012 9:14am
I have had two eBay buyers turn up to collect things in decatted 4.4's and they were very happy with their sound... Stood outside both cars i think they sounded ridiculous IMHO. I live on a fast road so at times you have to accelerate hard out of our driveway...
I have a decatted SC FF, i was nervous about this conversion as i didnt want mine sounding like an old boy racers corsa... And, it didnt luckily... I was told its because of the way the Supercharger disrupts the air, thats why its quieter and deeper in sound...
Craig Thumbs Up
Post #100059 2nd Jan 2012 9:30am
It.s been talked about on here quite a lot recently and with the new MOT regulations that just came in to force , if a vehicle had a CAT fitted at manufacture and it has subsequently had it removed that is a straight fail . 2008 MY Supercharged
Post #100060 2nd Jan 2012 9:33am
^^^^^ What he said, with the proviso that the car being tested is subject to a full cat test. Some older petrol engined cars had cats fitted at manufacture but were not subject to a full cat test.
Petrol and lpg engined cars are subject to a full cat test and will need the cat in place to get an mot. Nothing to do with whether they sound nice without a cat or not.
Post #100061 2nd Jan 2012 9:41am
bozmandb9
Is anybody aware of whether sports cats are available for the FFRR? If so would they still be caught out by the new MOT regs? Range Rover-less at the moment - Pining!
Post #100066 2nd Jan 2012 10:25am
klf400
thanks guys , not sure what to do at this point i do have a project kahn exhaust on my ff at the moment and it sounds great maybe a decat might be to loud inside the vehicle 1990 3.5 v8 defender
2011 4.4 TDV8 Vogue
faultmate extreme
rsw allcoms
Autel 906BT
Gap iiD tool
Post #100067 2nd Jan 2012 10:51am
speedymarktd6
United Kingdom 2010 Range Rover Vogue SE TDV8 Santorini Black
Why not cut out the oem cat and weld flanges on the exhaust and cat and make a de cat pipe that will go between then all you have to do mot time is bolt in your cat onto no6 Range Rover
Everyone needs a hobby
Post #100070 2nd Jan 2012 11:34am
I'd just find somewhere breaking a 4.4 and see if they have some used cat's instead Smile Bash the guts out and away you go.
When it comes to emmissons at MOT time if you have LPG installed they only do a smoke test. this is from personal experience and from what i've seen of the new rules its not changed.
yes they check for a cat, but if the box is there they wont take it off to check for internals Very Happy
problem being if its a project khan exhaust that includes freer flowing cat's then replacement ones will be a mare to find, so the flange weld in option would be the only way but is a faff for every MOT to climb under the car before and then after the MOT to swap them about...
Post #100072 2nd Jan 2012 11:48am
mzplcg
Yep, exactly what I've seen done in the past. As for emissions testing, find a quiet country garage where the sniffer could accidentally be shoved into a different vehicle. Whistle Whistle
Post #100105 2nd Jan 2012 5:47pm
bogie
seems like a lot of hassle to me for a few bhp ....get sports cats - you can get them custom made for any car for a few hundred quid...but you need 2, so it could be £7-800 for about 5bhp that you wont even notice on a 2.5ton vehicle Sad cheers
bogie
Post #100555 6th Jan 2012 7:59pm
