![]() | Home > Technical (L322) > Front water leak |
JustinP Member Since: 24 Oct 2010 Location: Cambridge Posts: 889 ![]() ![]() ![]() |
Any chance of posting a slightly larger photo? |
If you want to go down the route of a new windscreen why wait until you collect a stone chip.........Hammers were invented for a reason |
You'd be surprised how hard it is to crack a windscreen with a hammer, particularly when Autoglass are on their way to replace it. |
simon1233 Member Since: 13 Jun 2011 Location: Leyland, sometimes Darmstadt Posts: 650 ![]() ![]() |
nikbarber Member Since: 16 Dec 2011 Location: Warwick Posts: 36 ![]() ![]() ![]() |
Which bit do you want the larger photo of, JustinP? |
Last time I spoke about this to my Autoglass guy he told me that it didn't actually need to be broken before it could be replaced, as long as you 'think' it's broken that was good enough for him ![]() ![]() ![]() |
The 2nd photo whichhead already increased in size, have you up loaded another, of was I suffering from an iPhone problem? |
I just rotated the photo. Funnily enough, it looked small on my iphone as well, but fine on the PC. 2005 FFRR Td6 Vogue
kriswilson Member Since: 05 Oct 2010 Location: Aberdeen Posts: 106 ![]() ![]() ![]() |
Have you completely ruled out the sunroof drain tubes? This is what happened to me with the water ingress in the exact same place.
Hi Kriswilson,
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16311 ![]() ![]() ![]() |
You can smash the windscreen from the inside out using less than a tenth of the force you need from the outside inwards... Due to the curvature of the glass there is little strength if you hit the inside... Many lorry screens get broke when they jack the cab up to gain access to the engine...
duka Member Since: 11 Jan 2011 Location: uk Posts: 145 ![]() ![]() |
Any help appreciated folks?
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8369 ![]() ![]() ![]() |
If it's had a replacement screen (and often on old original screens) there can be rust that creeps under the bonding agent for the screen and causes it to lift, giving a leak... Or it hasn't been fitted properly and lifted....
Had car since new & it's only 4 & a bit years old so original screen & I don't think it would be rusty? Would rather not replace the screen until it's confirmed as the culprit! |
