Home > Technical (L322) > IIDTool from gap diagnostics ***Q & A ***
Page 48 of 49 <123 ... 474849>
JayGee
AFAIK you can’t open in one pull if you have driveway locking enabled as I looked into this a while back. I decided I’d rather have the safety of driveway locking rather than the convenience of one pull unlocking 2012 TDV8 Vogue (L322)
Post #692346 11th May 2024 10:24am
Andyyav
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Stornoway Grey
Thanks all, maybe I can get in the habit of pressing the Center button first, I like the drive away locking 1972 Series 3 full of character
1985 90 pick up went anywhere
1992 90 Exported
2007 L322 that was an experience
2010 D4 more versatile than a Swiss army knife, now gone
2011 L322 4.4 VSE
Post #692383 11th May 2024 5:43pm
pcourtney
I am down to five faults - working on the P2264 at the moment Smile
B1108-15 Driver's door central locking motor - circuit short
B1163-15 Left Mirror heater output - circuit short
P2264-00 Water in Fuel Sensor
U0128 -00 Lost comms with parking brake control module (2A)
U0140-00 Lost comms with body control module (2B)
Post #692495 12th May 2024 11:41pm
PDC
United Kingdom 2010 Range Rover Autobiography 5.0 SC V8 Barolo Black
Hi all, is it possible to have the taillights on as DLR's without having dip lights on too as in Scandinavia stetting.
Cheers. 2010 RR Autobiography 5.0 SC
2020 F-Pace SVR 5.0 SC
2018 RRS HSE Dynamic 3.0
2014 Disco XXV
2011 Disco 3.0
2009 RRS HST V8
Post #692748 15th May 2024 9:18pm
JayGee
All but the P2264 seem to be common spurious codes with no actual fault. 2012 TDV8 Vogue (L322)
Post #692751 16th May 2024 7:17am
JayGee
Cheers.
There are lighting settings for different markets in the menu so try them? 2012 TDV8 Vogue (L322)
Post #692752 16th May 2024 7:18am
PDC
Thanks, Yes I have tried Scandi & Canadian settings to no joy, I was wondering if there was a sub menu somewhere. 2010 RR Autobiography 5.0 SC
2014 Disco XXV
2011 Disco 3.0
2009 RRS HST V8
Post #692762 16th May 2024 8:53am
pretty sure it cant be done, but it might be worth doing a forum search.... ... - .- -.
Post #692786 16th May 2024 2:33pm
PDC
Cheers Stan, Yep I have done that & a google search too & nothing. I will give up then unless I could ask the guys at GAP to write a program for it. 2010 RR Autobiography 5.0 SC
2014 Disco XXV
2011 Disco 3.0
2009 RRS HST V8
Post #692813 16th May 2024 8:25pm
that sounds like a good plan Thumbs Up ... - .- -.
Post #692829 17th May 2024 7:17am
AndyRoo
Scotland 2012 Range Rover Westminster TDV8 Fuji White
2012 L322 Westie, Is it just me or does the chirp only work on unlock ?
I've tried with "superlock on single press" on and off and no difference. The documentation would suggest it should chirp on lock as well as unlock, (actually says arm & disarm).
I'd much rather have it chirp on lock to confirm it's locked rather than just on the unlock as I leave sometimes in the wee hours and my neighbours not going to be impressed with the 4am chirps with their windows open this summer (if we have one) so I'll have to turn that off.
Any thoughts ? Fuji White / Jet 2012 4.4 TDV8 Westminster
Post #692838 17th May 2024 8:48am
kevinp
I don't have any 'chirps' set on mine, I just look to see if the mirrors are folded in or not to know it's locked. Can't see the point in the 'chirp' for unlock really. Perhaps a job for the IID tool.
Post #692840 17th May 2024 9:12am
Georgi
Bulgaria 2011 Range Rover Autobiography Black 4.4 V8 Barolo Black
No sound in my case, the warning lights flash on arm/disarm and the mirrors fold/unfold. Came like that, I don't have the gap tool.
Any thoughts ?
 l322 2011 4.4 TDV8 Autobiography Black
l322 2007 3.6 TDV8
Post #697708 9th Aug 2024 2:14pm
invisible999
United States 2005 Range Rover HSE 4.4 V8 Chawton White
Can the current IDD Tool v3 do the following for L322 2005:
- Reprogramming ABS module
- Reprogramming BCU
- Re-pair keys after BCU replacement?
Post #697948 13th Aug 2024 4:58am
JayGee
The GAP website has all the info on what it does per model either in the downloadable manual or in the FAQ. 2012 TDV8 Vogue (L322)
Post #697953 13th Aug 2024 7:46am
