Home > Technical (L322) > IIDTool from gap diagnostics ***Q & A *** |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35217 |
http://www.gap-diagnostic.com/products/iidtool.html
9th Jul 2012 8:26am |
SteveMFr Site Sponsor Member Since: 22 Nov 2009 Location: Strasbourg, France Posts: 1641 |
Hi Stan,
10th Jul 2012 8:30am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16257 |
Steve, my nav on the move wont turn on either!
10th Jul 2012 8:50am |
Hi Craig, pls check your fw as well. We'll get it worked out.
10th Jul 2012 9:35am |
hi steve, i havnt used my RAC to change any settings on the LCM or BPM..the only CCF changes i've made is to switch the steering wheel in/out off.
10th Jul 2012 10:51am |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6714 |
I don't think automatic mirror folding is an option. I've certainly not seen it with V2.17 of the IIDtool F/W Got - 2017 SDV8 Autobiography in Loire Blue
11th Jul 2012 4:11pm |
tomthevet Member Since: 14 Jan 2012 Location: Scotland Posts: 283 |
Fair enough.
11th Jul 2012 4:25pm |
PaulB Member Since: 17 Jul 2011 Location: Hampton Posts: 877 |
The windows and roof will close if you press and hold down the locking remote. |
11th Jul 2012 10:42pm |
It's called 'lazy lock' not lazy alarm
Hi Stan, The MY will not make a difference: the IIDTool reads the coding index and automatically uses the correct data definitions for the vehicle. Nav on the go will not work with your present nav FW. You can have it updated, but there is still no 100% guarantee that this will work: for nav on the go to work, the nav FW version must contain the option and the region the vehicle is coded to must allow a change to nav on the go. Sorry, but as I noted above, we are not 'programming' in CCF editing, we are only making options available that LR has programmed into the ECUs. If you know of someone who has nav on the go unlocked with a UK coded car, you can update to the same FW version and make it work. (this might be a bit of valuable info for all, btw. If anyone reading this has nav on the go unlocked in the UK, please check your FW version and let us know!) And for your alarm chirp: there is a new build of FW v2.17 on the site. Christian has changed the parameters for chirp length and we hope this will work for you. You can delete the IIDTool updater files and program (uninstall) from your PC and then follow the original procedure to update your IIDTool again. The only difference will be that the updater will pop up a box staing that you already have v2.17 and if you'd still like to update to the same version. RRC 2Dr, RRC 4Dr, P38, and 2 L322s (wife thinks I'm nuts - prob right, too) |
12th Jul 2012 9:50am |
DMRR Member Since: 14 Apr 2010 Location: Northamptonshire Posts: 2027 |
Stan,
12th Jul 2012 9:54am |
morning steve,
12th Jul 2012 9:58am |
Stan, I am using the latest 2012 DVD too..... Land Rover Addict
12th Jul 2012 10:38am |
thanks for the info neil, but not to worried about this feature, but out of curiosity what is the version you're running.. ... - .- -.
12th Jul 2012 12:56pm |
Christian suggests entering the 'undefined' DRL option and navigating up and down. The IIDTool should then find the 'undefined' value - after which everything should function normally. RRC 2Dr, RRC 4Dr, P38, and 2 L322s (wife thinks I'm nuts - prob right, too) |
12th Jul 2012 6:35pm |
