Home > Technical (L322) > Heated Seat gets so hot it almost burns the legs |
Yesterday I was looking at the settings menu of the car (Faultmate software) for Bergxu and I noticed that there is a setting that controls the seat temperature. The seat temp can be set to medium and hot in that menu. It is for the MY02-09 range so yours sits right in the middle of that. If you know anyone with a T4 (dealer) or Faultmate or one of the other systems that allow setting changes you can ask them to check and set the temp medium. MY 2010 5.0 SC Galway green and sand interior!!
11th Feb 2012 3:44pm |
Flashman Member Since: 05 Jun 2011 Location: Windsor & Brentwood Posts: 1228 |
Nice one, I will look into that, was worried that there was something wrong with it, but if you are in arctic conditions I guess the high setting can be useful through all the clothing layers. Tom
11th Feb 2012 3:59pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16232 |
Only last week i had to change the rear swab on an 04 "54" FFRR as the seat heater had started to catch fire! It had burnt the seat cushion inside the seat! so maybe worth checking further on your car... The affected areas were black and crispy!
11th Feb 2012 9:00pm |
So possibly something serious then, is it fairly straight forward to get access to the seat interior/remove the seat covers? Tom
11th Feb 2012 10:03pm |
