Home > Technical (L322) > How to check I've had the FSR upgrade done?
Page 1 of 3 123>
mrblonde
United Kingdom 2003 Range Rover Vogue Td6 Adriatic Blue
Im sure my FFRR had the final stage resistor done before I bought her last year, but mid way through a house move and the service history is buried under 30 boxes of clothes I never wear anymore so I cant check that just yet Sad
Is there any way I can check to see if it was done, other than the reciepts in the folder? Can I physically look on the car? If so, what and where am I looking?
Having a battery drain problems and thought I'd start at the most common fault first (fingers crossed)
also, if the FSR has been upgraded, what are the chances of it failing/going wrong again and causing the drain issue again?
Cheers guys
Post #105031 2nd Feb 2012 6:20pm
Take ot out and have a look
My old FSR is shown in at the top in this picture
Post #105039 2nd Feb 2012 6:59pm
mrd1990
United Kingdom 2002 Range Rover HSE Td6 Oslo Blue
+1 for taking it out and having a look
My FSR was the original one and lasted 9.5 years without problems until it failed 2 months ago
I made a quick video of it's location here:
Complete guide here: http://bimma.me.uk/2009/03/13/replacing-th...kiii-2002/
Post #105067 2nd Feb 2012 7:48pm
mrblonde
Cheers guys
Have the upgraded ones been known to fail ever? Just wondering.........
Post #105227 3rd Feb 2012 3:17pm
They only cost about £30-£35 for a genuine one so worth changing if you are in doubt
Post #105230 3rd Feb 2012 3:28pm
Polux
2005 Range Rover Autobiography 4.4 V8 Monte Carlo Blue
huh this causes a battery drain??? whats a fsr whats it do i am having battery drain issues 2005 model
Post #105253 3rd Feb 2012 5:03pm
polux, looky here..
http://www.fullfatrr.com/forum/topic781.html?highlight=fsr ... - .- -.
Post #105257 3rd Feb 2012 5:07pm
Final stage resistor which controls the heater. When they go faulty they can drain the battery and also give heater motor problems
Post #105258 3rd Feb 2012 5:08pm
I'm on my third one in three years .
Post #105271 3rd Feb 2012 5:34pm
mrblonde
cheers guys
Wheres best to get one from? Local Dealership? if so any of you got the part number to hand?
Cheers will give it a try
What other symptoms should i be experiencing if its given up, other than a dead battery?
Post #105443 4th Feb 2012 4:54pm
Land Rover are around £35
Part No. JGO 000021
Post #105448 4th Feb 2012 5:45pm
mrblonde
Cheers guys, forgot to ask, if/when one does fail, is that when you are likely to experience battery drain?
Post #105648 6th Feb 2012 8:17am
yes it is mr b... ... - .- -.
Post #105649 6th Feb 2012 9:29am
markdotreed
Just out of interest does anyone know if there is a similar resistor on the 'classic' controlling the fan?
My heater fan will only work on full blast (number III) and not on II or I. I've always been under the impression that to change the fan on a classic is a dash out job so have never bothered but if it's just a resistor of some sort then maybe I'll investigate further. Regards
Mark
2009 D4; 1993 Classic 3.9 VSE
Post #105655 6th Feb 2012 10:36am
mrblonde
Thanks again guys Bow down
Got to fit a new battery this weekend or early next week, and also going to change the FSR to be sure its not that playing up, should I do the batt first, or the FSR while theres zilch power to the car? Or doesnt it really matter?
Just dont want anything going 'pop' on me
Post #106382 9th Feb 2012 5:17pm
Page 1 of 3 123>
