Home > Technical (L322) > How to check I've had the FSR upgrade done?
Page 2 of 3 <123>
mrblonde
United Kingdom 2003 Range Rover Vogue Td6 Adriatic Blue
apologies for the other thread scarey, wasnt sure about carrying it on in here as Ive drifted from FSR to changing battery....
Cool, I'll get it off and charged and to my local Varta dealer to check, am seriously thinking about buying a Bosch S5 (110Ah, 920cca) from my local EuroCarParts as theyre only 2 miles away
Post #106423 9th Feb 2012 6:41pm
@markdotreed
Almost all cars have multistage resistor packs to control the heater blower .
RR Classics do.
Classic symptom of failure is when the blower only runs at maxmum speed and no other.
Not expensive, might be worth a pm to Dan at Duckworths.
The resistor pack is usually located in the side of the heater blower inlet air duct under the dash.
Post #106434 9th Feb 2012 7:36pm
mrblonde
Quick update guys
Got my new FSR today so hopefully try fitting it tomorrow, I've got the 'how to' guide printed off, anything I should watch for?
Then new Bosch battery goes on Smile
Post #107186 13th Feb 2012 8:37pm
The large circular indent in one side of the FSR is the top face. Smile
You may need to know that. Laughing
Post #107191 13th Feb 2012 8:57pm
bozmandb9
mrd1990 wrote:
+1 for taking it out and having a look
My FSR was the original one and lasted 9.5 years without problems until it failed 2 months ago
I made a quick video of it's location here:
Complete guide here: http://bimma.me.uk/2009/03/13/replacing-th...kiii-2002/
Does anybody know if these instructions apply to the 2006MY?
Thanks,
David Range Rover-less at the moment - Pining!
Post #107231 14th Feb 2012 7:00am
mrblonde
Quick update, from someone with 2 left hands I managed to change the FSR was a bit of a pig to get at but it's done, new battery on tomorrow when my hired muscle comes round to help lift the things out and in Rolling Eyes
Post #107319 14th Feb 2012 2:05pm
SAppie
Has anyone with a TDV8 / 2007MY onwards ever had this FSR issue?? MY2007 Vogue SE TDV8 - Tonga Green / Sand
MY2005 Discovery 3 - Silver / Biege
Post #107401 14th Feb 2012 7:36pm
mrblonde
Hmmmm.... Bloody car!! Right, fitted a new FSR 10 months ago, and think it may of gone again? I opened her up today (after putting a new S5 Bosch on it), opened passenger door and leaned in to passenger footwell to pull the fuse for the FSR, as I pulled it out, I'm pretty sure I heard something come to a stop, possibly a fan running very very quietly, as I pulled the fuse it stopped
Replace FSR again??
Post #158344 18th Dec 2012 5:36pm
Could well have been the air temperature sensor fan running and stopping when you pulled the fuse.
Located behind the small grille on the left of the air distribution selector switches.
Post #158380 18th Dec 2012 8:21pm
mrblonde
Cheers nice
Would that fan be running as soon as I unlock the car in the morning, before it has been started??
Apologies for the back to basic questions
Post #158382 18th Dec 2012 8:31pm
Yes the fan switches on as soon as you open (or unlock?) the door.
Post #158385 18th Dec 2012 9:01pm
Nomad
United Kingdom 2012 Range Rover Autobiography 5.0 SC V8 Zermatt Silver
How long is that air temperature sensor fan supposed to stay on for?
I think I've got a battery drain (Voltage 12.3 after running the car for most of the day yesterday) and I can hear the small fan for several minutes after I switch off. I waited for at least 8 minutes but it was still running. Hooked up the battery charger and will check again tomorrow. 2012 5.0L S/C
Previous:
3.6 TDV8
4.4 HSE
P38 4.6 HSE
Classic 3.9
90 County
Series3 Lightweight
Post #158542 19th Dec 2012 6:34pm
Nomad
Update:
Charged the battery fully overnight. Disconnected and attached Multimeter in series between the earth cable and negative battery post. Amps settled down to 1.92A after a few minutes and then dropped to 0.02 / 0.03A after 18 mins.
So it doesn't look like I have a serious parasitic battery drain.
I later sat in the vehicle and waited for it to go to sleep. After 18 mins the whirring sound from the a/c sensor fan stopped so that must be the 1.9A load. But it does stop!
I'll have to wait and see why my battery voltage had dropped to 12.3 despite being out for a run. It was showing 12.7 today after starting it, running diagnostics to read and clear all faults (with the IID tool of course!) resetting clock time and date and putting it back in the garage. All appears well. I'll check again tomorrow.
To repeat a question from further up this thread: Has anyone with a TDV8 had the FSR problem? 2012 5.0L S/C
Previous:
3.6 TDV8
4.4 HSE
P38 4.6 HSE
Classic 3.9
90 County
Series3 Lightweight
Post #158775 20th Dec 2012 3:01pm
Please note my photo tutorial has moved from bimma.me.uk to
http://metricrat.co.uk/replacing-the-final...kiii-2002/ .
Post #158838 20th Dec 2012 6:32pm
adesmith
England 2002 Range Rover Vogue 4.4 V8 Zambezi Silver
sorry to resurrect this thread but I have battery drain as well. Sat in the car tonight and heard the fan slowly whirring. Pulled a fuse, can't remember which and I heard another sound coming from the drivers footwell like a kettle boiling. I removed fuse 12 and it stopped.
Is that the FSR? And would you think its a fault? What makes it run? The car hadn't been used for about 3 hours.
Post #171200 9th Feb 2013 7:48pm
Page 2 of 3 <123>
