Home > In Car Electronics (L322) > reversing camera......works sometimes |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35447 |
video cable normally has a centre and outer cables...connect centre to centre etc.. |
24th Feb 2012 3:12pm |
i mess around with cctv cameras around the house and i agree the inner cable sometimes is very thin.. |
24th Feb 2012 3:21pm |
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1518 |
Also with the fine Coax it's very easy to get ground loops. We use RA8000 in work sometimes with 1.0/2.3 connectors which are similar to the connector on the camera but with additional locking mechanisms and we sometimes with digital communications have a real nightmare and end up re-terminating them.
24th Feb 2012 3:26pm |
Lolo Member Since: 16 Feb 2012 Location: Leinster Posts: 608 |
ok i was thinking bout a new loom to be on the safe side, but i havent been able to get a wiring diagram..with the spoiler off where do the wires go..? |
24th Feb 2012 3:52pm |
Installed the camera, should have been straight forward but as usual with these cars it wasn't..! The screwhead that keeps the casing on the camera was worn so that took a lot of effort to get off. Once I got angry with it it came off in one piece..! Then the wiring should have been straight forward but as stated before my connections were cut. Happy days, working camera.. had a look at the old one and I could see moisture inside the glass so that was clearly the culprit to the problem |
25th Feb 2012 4:57pm |
carlos50 Member Since: 03 Feb 2011 Location: North England Posts: 717 |
Will the camera from a 2010 FFRR retrofit into a 2007 MY which has a camera already but a poor one at that.
25th Feb 2012 5:59pm |
I'm planning a how to on this, I've got a 2010 camera just waiting for the loom.
25th Feb 2012 6:27pm |
Is the loom custom made? Does the 2010 camera mount onto the spoiler of an 07 correctly or does it need mods?. Cant wait for your how to !! |
25th Feb 2012 7:18pm |
Hi, it's a standard part for 2010.
25th Feb 2012 10:19pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16302 |
If you need any help/pics just let me know pal... Can PM you my number if it helps...
26th Feb 2012 12:52am |
See, told you he was really helpful!
26th Feb 2012 9:50am |
Try to be...
26th Feb 2012 11:41am |
Has the loom arrived, am keen to see the how to for the 2010 upgrade |
3rd Mar 2012 12:57pm |
Hey Carlos.
3rd Mar 2012 3:59pm |
