Home > Technical (L322) > Fan noises
Renegade2
United Kingdom 2010 Range Rover Vogue SE TDV8 Stornoway Grey
Fan noises
I have tonight been out trying to solve my FBH touchscreen problem with no avail. When sitting in the car and turning the key to position 1 i noticed a fan type noise that seems to be coming from the left passenger side in behind the CD Changer area, no fans any where else in position 1.
Its not from the FBH as i opened the bonnet
Any one have any ideas as to what this could be. I didnt think that there was anything over there other than the vents in the footwell and side vents and there is nothing coming out of them.
Post #102763 21st Jan 2012 12:41am
Dogman
United Kingdom 2007 Range Rover Vogue TDV8 Zermatt Silver
Hi
I've suffered from this 'fan' noise coming from the glovebox.
When I opened the bonnet it's definitely coming from behind the engine bay and is intermittent.
Any ideas would be much welcomed, BTW it's not fan dependent, even wilth blower off it still happens on occasion.
Post #102785 21st Jan 2012 11:55am
Jr-auto-electrics
England 2004 Range Rover Vogue Td6 Java Black
Hi
Pull fuse 59 and see if goes away. RANGE ROVER 04 TD6
RANGE ROVER ULTIMATE EDITION 2012
UPGRADE.
MK 4 SATNAV
http://www.flickr.com/photos/jrautoelectrics/
Post #102807 21st Jan 2012 1:44pm
Renegade2
Yep pulled fuse 59 which is for the FHB but did not make any difference. It is definatly in by the glovebox but i can not quite pin point it. I opened the bonnet and could not hear anything in there.
Post #102836 21st Jan 2012 4:25pm
Jr-auto-electrics
Are you sure it's not coming from your temperature control
Panel below your screen???
And you can hear the fan at the rear which draws air through and across the
Temperature sensor. RANGE ROVER 04 TD6
UPGRADE.
MK 4 SATNAV
Post #102848 21st Jan 2012 6:22pm
Dogman
As earlier, I don't know if it's the same but it does happen when the FBH is on and also can happen when the car is unlocked.
Problem is it's intermittent so a bit tricky to pull the fuse as most times it does not whine for long enough to get to the fuse.
As per Renegade it is defo located in the glovebox region, not engine bay, not anywhere on the dash except in the glovebox.
Thx for the ideas
Post #102916 21st Jan 2012 11:29pm
Johnte
I'm sure I read on here a while back about a fan in the glove box area, that circulated the air when the car was first unlocked. I think it was something to do with interior temp sensors ( Although I can't find it any more in 'search')
Post #102930 22nd Jan 2012 11:19am
